Warning message
1700 ADSL wic card
Answered Question
Jan 2nd, 2007
I want to configure two different adsl lines from two different operators for
Is there any ADSL WIC card with two ADSLoPOTS port or i need to have two different cards for each line.
In both the cases please suggest me the PART no required for cisco 1700
Correct Answer by spremkumar about 10 years 7 months ago
Hi Sachin
You can make use of Cisco 1841 Series router which comes with 2 WIC slots which you can make use for installing the ADSL cards and 2 ethernet ports for your local lan..
http://www.cisco.com/en/US/products/ps5875/index.html
I feel its the best bet available out there when compared to Cisco 1700 series routers since the later may be phased out by any time..
regds
Overall Rating: 5 (1 ratings)
xs2sachin Tue, 01/02/2007 - 22:48
model not yet decided i want to use some low end router. can you suggest me some models matching my requirements --
--two adsl wan connections
-- one lan connection
-- static routing
I want to use these two adsl wan connections in redundancy or load balancing what configuration is required
Correct Answer
spremkumar Tue, 01/02/2007 - 23:00
  • Red, 2250 points or more
Hi Sachin
regds
