Warning message
Auto-RF
Jan 4th, 2007
I have a question regarding Auto-RF with the Cisco Controllers.
1. Does Auto-RF require a specific number of AP's to function correctly? 4 AP's minimum is what I have heard.
Thanks!
Sean.
Benjamin Solero Thu, 01/04/2007 - 13:29
  • Cisco Employee,
Hi Sean,
The Transmit Power Control (TPC) Algorithm (used in Radio Resource Management or auto-rf) adjusts an APs transmit power down when the third loudest neighbor is heard at -65dBm (default value) or greater. That's likely where you got the minimum number.
There's much more to RRM than TPC. For an in-depth and well-written explanation of RRM, please read the document at the following URL:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml
Best Regards,
Ben
Rob Huffman Thu, 01/04/2007 - 13:56
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sean,
Just to add a note to Ben's always excellent info. This parameter may have been the one that you heard of.
Power Neighbor Count (3) - The minimum number of neighbors an AP must have for the TPC algorithm to run. This is a display-only field and cannot be modified.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#group_algorithm
Take care guys!
Rob
