IPT VOIP Access layer Switches
Jan 4th, 2007
For a new Building with 3 floors, 250 Users per floor using 2 x 6509/720 Sup's for the Core. Which Access layer switches would you use?
Would you use Layer2 (RPVST) or Layer3 (EIGRP stub) at the Access Layer?
3750 Cluster PoE EMI software
Pro's Resilient
Con's Expensive, Switches are now 3-4 years old possible EOL soon.
4506 4507R 4510R Sup2+ PoE Blades
Pro's Cheap
Con's Old technology based on 4006 Architecture 6gbps backplane,
If one power of the power supplies fails some of the phones will stop working
possible EOL Soon
6509 Sup32 PoE Classic line Blades
Pro's
Con's most expensive
Overall Rating: 4.5 (2 ratings)
eofelt Thu, 01/04/2007 - 13:33
  • Bronze, 100 points or more
2 per floor: 4506 or 1 4510 with External AC Power Shelf (in a no downtime/tight SLA environment). Split power across a properly rated UPS for no exceptions.
Provides 20% + for growth
Your environment is sim' to mine. No problems to report.
PVST+/RPVST
mark.cronin Thu, 01/04/2007 - 13:37
When was this deployed?
Which IPT vendor are you using?
How are you measuring Latency / Jitter / Voice Quality?
eofelt Fri, 01/05/2007 - 04:33
>>>> Started Oct 06, dep' still ongoing
>>>> All Cisco devices aggregate to Avaya Call Managers and gateways (Company's choice)
>>> Across a modern LAN is not an issue. Across the WAN, Avaya brought in a small, test box (call sim/statistical measurement) at each end of the access layer with various voice codecs. G.729 is employed here.
Keys are a clean WAN circuit and good QoS implementation.
