01-05-2007 12:46 AM - edited 03-03-2019 03:15 PM
If i view "sh int serial" as below, notice that loopback not set. Is this loopback option useful only in wicg703 type card with inbuilt DSU? Or is it useful in normal sync serail ports such as v.35 etc
home#sh int se 0
Serial0 is administratively down, line protocol is down
Hardware is HD64570
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
01-05-2007 03:43 AM
Yes , its also useful in normal sync serial ports for giving a local loop to itself and check if the local interface is fine.
Hope this helps
regards
vanesh k
01-07-2007 06:16 PM
Vanesh,
thanks. But when i enable the loopback on a v.35 serial port, i see that loopback is set.But the interface never came up...any pointers on how to use loopback on v.35 will be greatly helpful.
Regds
Jay
01-07-2007 09:38 PM
Can u enable the same command in any other free interface and check , might be the interface might have problem.
also , pls post the interface config with loopback set
regards
vanesh k
