Warning message
AAA Accounting report not showing commands issued.
Answered Question
Jan 5th, 2007
Hello all, I am having trouble with AAA accounting on my ACS appliance 4.0. When I view the accounting log it lists connections, protocols and IP addresses but not the commands that have been run on the particular switch. When I do debug AAA accounting I do see ouput but when I debug Tacacs accounting I don't see anything. An exammple of my config is:
aaa new-model
aaa group server tacacs+ ACS
server [ip addresss here]
aaa accounting exec default start-stop group ACS
aaa accounting commands 0 start-stop group ACS
aaa accounting commands 15 start-stop group ACS
tacacs-server key [key here].
I've left out the authentication part of the config (on the above example) as this is working fine.
Anyone any ideas why the actual commands are not being captured on the ACS?
Thanks in advance.
Correct Answer by mstannard about 10 years 7 months ago
In ACS, the Command Accounting is logged to the TACACS+ Administration log not the TACACS+ Accounting log! Don't ask me why, it just is. At least it is on mine and took me a while to discover as well.
Hope this helps
Mike
Overall Rating: 5 (1 ratings)
royalblues Fri, 01/05/2007 - 10:01
  • Green, 3000 points or more
Hi Paul,
Make sure you have the following commands under the vty interfaces of the devices
line vty 0 4
accounting connection
accounting exec
HTH, rate if it does
Narayan
network.king Sat, 01/06/2007 - 05:30
  • Silver, 250 points or more
Can u include the default under the accounting commands and check
aaa accounting commands 15 default start-stop group ACS
Hope this helps
regards
vanesh k
paulhowlett_2 Mon, 01/08/2007 - 06:43
Hi, I've entered the commands (on a Catalyst 4948)but they [commands] don't show in the config.
I have also entered the 'default' command as suggested too. Still nothing under the 'cmd', 'cmd-arg'or 'event' in the ACS appliance Accounting log.
Thanks.
mstannard Tue, 01/09/2007 - 03:05
Hope this helps
Mike
Correct Answer
mstannard Tue, 01/09/2007 - 03:18
Hope this helps
Mike
paulhowlett_2 Tue, 01/09/2007 - 07:53
You are spot on! I expected it to be in the accounting log but - the obvious place I would have thought. Thank you.
