ios vpn, vpn client IKE problem
Jan 6th, 2007
I try to set up a vpn connection between a 1812 router and software vpn client but despite the ike atts are accepted the router disconnects the client.
"debug crypto isakmp" results:
002458: *Jan 6 22:04:55.751 UTC: ISAKMP:(0):Checking ISAKMP transform 13 against priority 3 policy
002459: *Jan 6 22:04:55.751 UTC: ISAKMP: encryption DES-CBC
002460: *Jan 6 22:04:55.751 UTC: ISAKMP: hash MD5
002461: *Jan 6 22:04:55.751 UTC: ISAKMP: default group 2
002462: *Jan 6 22:04:55.751 UTC: ISAKMP: auth XAUTHInitPreShared
002463: *Jan 6 22:04:55.751 UTC: ISAKMP: life type in seconds
002464: *Jan 6 22:04:55.751 UTC: ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
002465: *Jan 6 22:04:55.751 UTC: ISAKMP:(0):atts are acceptable. Next payload is 3
002466: *Jan 6 22:04:55.751 UTC: ISAKMP:(0): processing KE payload. message ID = 0
002467: *Jan 6 22:04:55.755 UTC: ISAKMP:(0): processing NONCE payload. message ID = 0
002468: *Jan 6 22:04:55.755 UTC: ISAKMP:(0): vendor ID is NAT-T v2
002469: *Jan 6 22:04:55.755 UTC: ISAKMP (0:0): Unknown Input IKE_MESG_FROM_PEER, IKE_AM_EXCH: state = IKE_READY
002470: *Jan 6 22:04:55.755 UTC: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_AM_EXCH
002471: *Jan 6 22:04:55.755 UTC: ISAKMP:(0):Old State = IKE_READY New State = IKE_READY
Client Logs:
Attempting to establish a connection with xx.xx.xx.xx
206 23:19:41.890 01/06/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to xx.xx.xx.xx
207 23:19:41.890 01/06/07 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
8 23:19:41.890 01/06/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
209 23:19:47.234 01/06/07 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
210 23:19:47.234 01/06/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to xx.xx.xx.xx
215 23:20:02.234 01/06/07 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=9C90B0C5922BD327 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
217 23:20:02.734 01/06/07 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "xx.xx.xx.xx" because of "DEL_REASON_PEER_NOT_RESPONDING"
"sh crypto isakmp sa"
STATE=AG_NO_STATE status ACTIVE
ISR IOS = Version 12.4(6)T3
vpn client version= I tried with different versions of 4.8 and 4.0 clients
Oszkar
Overall Rating: 2 (1 ratings)
Daniel Voicu Sun, 01/07/2007 - 01:58
  • Silver, 250 points or more
The IKE is sone on UDP 500, you will try then NAT-T, that is UDP 4500. Make sure you have this port opened.
Please rate if this helped.
Daniel
oszkari Sun, 01/07/2007 - 06:13
Hi Daniel,
No UDP ports are filtered neither in the router nor in the client side.
Any hint?
Oszkar
Daniel Voicu Sun, 01/07/2007 - 09:37
Hi Oszkar,
Can you check http://cisco.com/application/pdf/en/us/guest/products/ps6659/c1650/cdccont_0900aecd80313bdf.pdf
Also some useful links on:
http://cisco.com/en/US/products/ps6659/products_ios_protocol_option_home.html
Studying the configuration there you might find what is wrong in your config.
Daniel
