Warning message
How to submit a FSWM feature request?
Jan 8th, 2007
What is the proper method for customers to submit feature requests?
The specific feature I'm interested in deals with multiple context mode, where it would be extremely useful to re-use certain configuration elements (names, object-groups, etc.) in multiple contexts. If you do this currently, you have to define them in each context where they will be used and, if/when they need to be edited, you have to do so in each context. I see a need for a feature where you could define names and object-groups in the admin context or system space, and use something like an "inherit" command in the other contexts to re-use these elements. Of course, you also need a mechanism to force the inherited elements to be updated, and associated acls recompiled, when the "master" instances are updated. So, if anyone from the product development team is listening ...
awaheed Fri, 01/12/2007 - 10:29
  • Cisco Employee,
Hi Lowen,
You will need to get in touch with your local Cisco SE and ask them to open a PERs request on your behalf which they can do and the right marketing contact will be assigned the request to consider for a future release.
Hope this helps,
Rgds,
Aamir Waheed
Product Manager
Cisco Systems, Inc.
