pix 6.3.5 forwarding a range of ports to internal IP
Jan 9th, 2007
I have a pix with one static outside IP address and have been asked to forward a whole bunch of UDP and TCP to an internal (natted) IP address. I have done static mappings before but for only single port numbers.
Below is the range of ports to forward
qsig 4029 tcp
qsig1 6400-8191 tcp
ras 1718-1719 udp(already in fixup)
rtp/rtcp 1500-1503 udp
megaco+ 2944 tcp
rtp/rtcp1 16384-16511udp
rtp/rtp2 20480-24575udp
presumably I have to define these ranges in access lists but is there a way of defining the static mapping to a name or "port object" group rather than write out the mappings line at a time for each port number?
cheers in advance
G
Overall Rating: 4 (2 ratings)
gordinho01 Tue, 01/09/2007 - 10:45
Thanks for the link. After doing a bit of research (bit new to port object grouping) I have created the following group objects
object-group service qsig1_tcp tcp
port-object range 6400 8191
object-group service rtp_udp udp
port-object range 1500 1503
object-group service rtp1_udp udp
port-object range 16384 16511
object-group service rtp2_udp udp
port-object range 20992 24575
object-group service rtp3_udp udp
port-object range 20480 20991
now I've added the following access list lines
access-list internet permit tcp any host object-group qsig1_tcp
access-list internet permit udp any host object-group rtp_udp
access-list internet permit udp any host object-group rtp1_udp
access-list internet permit udp any host object-group rtp2_udp
access-list internet permit udp any host object-group rtp3_udp
but now I'm stuck with respect to mapping the object-group to the natted LAN IP
any ideas?
gordinho01 Tue, 01/09/2007 - 11:29
Thanks for replying. I am unsure as to the implication of adding that line.
"static (inside,outside) tcp 1.1.1.1 640 access-list (name)"
the pix in question already has a bunch of static mappings to other internal/natted IP's and the access list "internet" also covers these out to in permits.
static (inside,outside) tcp interface ftp-data 192.168.2.253 ftp-data netmask 255.255.255.255 0 0
static (inside,outside) tcp interface ftp 192.168.2.253 ftp netmask 255.255.255.255 0 0
static (inside,outside) udp interface snmp 192.168.2.253 snmp netmask 255.255.255.255 0 0
static (inside,outside) udp interface snmptrap 192.168.2.253 snmptrap netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 2944 192.168.2.251 2944 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 4029 192.168.2.251 4029 netmask 255.255.255.255 0 0
gordinho01 Fri, 01/12/2007 - 04:36
thanks for taking time to look at this. The client gave me a second external IP I could define on the pix in a static + access list so I just forwarded all those object groups...bit of a cop out I know...thanks anyway
G
