Warning message
Dot1X on router 877
Jan 9th, 2007
I need to add the command "dot1x guest-vlan" on Router 877 and I use the IOS 12.4T11. The command is not available on cli but I've found it on the documentation. http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008077520e.html
Somebody know why?
amit-singh Tue, 01/09/2007 - 09:38
  • Blue, 1500 points or more
Fabrice,
The command in 12.4T11, is only supported on Etherswitch modules on ISR routers. Its is not supported on 877 router.The link above has this info.
-amit singh
