MCS 7815-I2 won't boot
I've been trying to go through the installation instructions for the MCS 7815-I2. I've gotten through the installation part and am trying to move on to the post installation. However the boot process will stop soon after it tries to get an ip address. I get a screen asking me if I want to dump diagnosis data to a usb device, which I've done. I've tried having the ethernet plugged in and not having it plugged in. I'm set up for DNS usage instead of a static IP. As a test case, I tried taking a router(switch) with nothing plugged into it that was known to work with normal PCs and tried getting the machine to boot while connected to that. It still didn't work. After examining the dump I saw logs saying that it had retrieved the nameserver addresses and didn't have any errors other than a very generic looking one. A log from one of the tests is attached. Any help would be greatly appreciated. Thanks.
Jan 11 09:13:33 localhost local7 5 rc.sysinit: Checking filesystems succeeded
Jan 11 09:13:33 localhost local7 5 rc.sysinit: Mounting local filesystems: succeeded
Jan 11 09:13:34 localhost local7 5 rc.sysinit: Enabling swap space: succeeded
Jan 11 09:13:35 localhost local7 5 microcode_ctl: microcode_ctl startup succeeded
Jan 11 09:13:35 localhost local7 5 sysstat: Calling the system activity data collector (sadc):
Jan 11 09:13:35 localhost local7 5 rc: Starting sysstat: succeeded
Jan 11 09:13:48 localhost local7 5 kudzu: succeeded
Jan 11 09:13:48 localhost local7 5 kudzu: Updating /etc/fstab succeeded
Jan 11 09:13:48 localhost local7 5 rc: Starting csaupdate: succeeded
Jan 11 09:13:48 localhost local7 5 csaadapt: Warning: loading /lib/modules/CSCOcsa/csashims will taint the kernel: non-GPL license - cisco
Jan 11 09:13:48 localhost local7 5 csaadapt: See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Jan 11 09:13:48 localhost local7 5 csaadapt: Module csashims loaded, with warnings
Jan 11 09:13:48 localhost local7 5 rc: Starting csaadapt: succeeded
Jan 11 09:13:48 localhost local7 5 iptables: succeeded
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.ip_forward = 0
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.tcp_keepalive_time = 300
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.tcp_keepalive_probes = 2
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.tcp_keepalive_intvl = 10
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.tcp_retries2 = 8
Jan 11 09:13:48 localhost local7 5 sysctl: net.ipv4.conf.default.rp_filter = 1
Jan 11 09:13:48 localhost local7 5 sysctl: kernel.sysrq = 0
Jan 11 09:13:48 localhost local7 5 sysctl: kernel.core_uses_pid = 1
Jan 11 09:13:48 localhost local7 5 sysctl: kernel.core_pattern = /var/log/active/core/core.%p.%s.%e.%t
Jan 11 09:13:48 localhost local7 5 sysctl: kernel.rtsig-max = 10240
Jan 11 09:13:48 localhost local7 5 sysctl: vm.bdflush = 50 500 0 0 100 500 80 50 0
Jan 11 09:13:48 localhost local7 5 network: Setting network parameters: succeeded
Jan 11 09:13:49 localhost local7 5 network: Bringing up loopback interface: succeeded
Jan 11 09:13:49 localhost local7 5 ifup:
Jan 11 09:13:49 localhost local7 5 ifup: Determining IP information for eth0...
Jan 11 09:14:43 localhost local7 5 NET: /sbin/dhclient-script : updated /etc/resolv.conf
Jan 11 09:14:43 localhost local7 5 ifup: done.
Jan 11 09:14:45 localhost local7 5 network: Bringing up interface eth0: succeeded
Jan 11 09:14:48 localhost local7 5 netfs: Mounting other filesystems: succeeded
Jan 11 09:14:48 localhost local7 5 autofs: automount startup succeeded
Jan 11 09:14:48 localhost local7 5 sshd: succeeded
Jan 11 09:15:02 localhost local7 5 INSTALLATION_FAILED: chmod: changing permissions of `/mnt/usb/install.2007-01-11.09.14.48' (requested: 0666, actual: 0755): Operation not permitted
