IOS upgrade of PIX to ver 7.0
bvsnarayana03
Level 5
Level 5
I'm planning to upgrade my PIX 525 from ver 6.2 to ver 7.0.
Pls let me know, if the configuration will be intact after upgrade or will any changes be required. I'm taking limited downtime for my production, & would like to avoid last moment hiccups.
5220
Level 4
Level 4
The configuration will change as the some of the commands are changing (vpn groups, interfaces not are router like configurable). Save your old config prior.
Carefull with this in the production and plan ahead.
Check http://cisco.com/en/US/products/hw/vpndevc/ps2030/prod_installation_guides_list.html
Please rate if this helped.
Daniel
owensgl
i would backup the config because the upgrade use to ignore the IPSEC key info that will result in the IPSEC not coming up
GO
