Warning message
2960 SW Password Recovery Question
Answered Question
Jan 14th, 2007
My colleague by mistake has entered the command: "enable secret level 5" on the 2960 SW. He did not enter any other words after "5", but he is not able to access the SW with blank password! I am just wondering what the password will be in this case and whether he needs to perfom password recovery from the ROM monitor mode.
Haitham
Correct Answer by ankbhasi about 10 years 7 months ago
Hi Haitham,
Can you try password as "level 5" and if that does not work go ahead with password recovery mentioned by Saurabh in his post.
Ankur
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Sun, 01/14/2007 - 22:26
  • Cisco Employee,
Hi Haitham,
Ankur
haithamnofal Sun, 01/14/2007 - 23:50
Hi Ankur,
Sorry, but what do you mean by try password level 5? He tried to enter blank password but he could not get access?
Haitham
abhishek_nandavat Mon, 01/15/2007 - 00:25
  • Silver, 250 points or more
Ankur meant to say, that you need to try the string "level 5" as the password.
Hope you get it.
AbhisheK
haithamnofal Mon, 01/15/2007 - 01:58
Yes, it accepted the password as "level 5". But strange it accepted it as a password and not as a command!!
Many Thanks,
Haitham
