pings from ASA or ASA
Jan 15th, 2007
I have a site-to-site VPN between an ASA 5505 and a PIX 501. The tunnel connects to private LANs A and B.
Now from LAN A I can ping hosts on LAN B.
From ASA on LAN A can ping hosts on LAN A.
But I can't ping from ASA on A hosts behind PIX on remote LAN B. And vice versa from PIX on LAN B it is not possible to ping hosts on LAN A.
I can successfully ping Internet addresses from both ASA and PIX.
ICMP is allowed on both ASA and PIX.
Should specifically allow ICMP for the tunnel? What else might I miss?
Thank you.
Alex
ccna2 Mon, 01/15/2007 - 02:20
You need to issue the command: "management-access inside" in order for this to work.
Thomas BJ.
augnevenok Mon, 01/15/2007 - 13:59
"management-access inside" is enabled on both devices. Still cannot ping from device hosts that are behind the other device across VPN tunnel.
What should be enabled/allowed for these pings to come through?
Thank you very much.
Alex
ccna2 Mon, 01/15/2007 - 23:38
Hi Alex,
On each Firewall is the inside interface IP address included in the access-list specifying the interesting traffic?
Do you have filters configured?
Are you correctly using the ping command: "ping inside x.x.x.x"?
Thomas BJ
