Warning message
Multicast over GRE tunnel
Jan 15th, 2007
I have a Catalyst 3750 Metro running 12.2(25)EY4 on site A and a 2811 running 12.3(11)T4 on site B. There is an MPLS backbone in between and a GRE tunnel configured from site A to site B. At site B there are several hosts receiving multicast flows from site A.
The multicast flows arrives at site B, but the application running on hosts discards packets because they arrive out of sequence.
I tried to force sequencial trasmission of packets with the command ?tunnel sequence-datagrams?, but multicast packets are still discarded with the same log. Below the configuration of tunnel interface on both sites
site A
interface Tunnel2
ip address 192.168.105.105 255.255.255.252
ip pim sparse-dense-mode
keepalive 10 3
no clns route-cache
tunnel source Loopback0
tunnel destination 192.168.105.190
tunnel checksum
end
site B
interface Tunnel1
description Multicast verso router CED Master
ip address 192.168.105.106 255.255.255.252
ip pgm router
keepalive 10 3
tunnel destination 192.168.105.254
tunnel checksum
Could someone help me?
Stefano
lgijssel Mon, 01/15/2007 - 05:39
  • Red, 2250 points or more
The command "tunnel sequence-datagrams" does not order packets for transmission. It rather drops packets that arrive out-of-sequence. You do not want to use this so I suggest that this command is removed from both routers.
To solve the issue, first try to reduce the transmissionrate of your multicast application (by reducing quality or resolution) If this gives an improvement the packets are probably asymetrically load-balanced on the MPLS backbone. In that case, your MPLS provider should make arrangements to solve this issue.
Otherwise, you might need to trace some packets and determine wheter you are having out of sequence packets or not and measure the variation in delay on the MPLS network.
Leo
