QOS WRED question about router setup
Jan 15th, 2007
Hi...I am in the process of looking at QOS as a means of prioritizing traffic across a 10meg congested link. Is there a formula for determining the number of minimum threshold buffers to set? I'm setting this up on a 2811 router and am having trouble determining values to use with the random-detect command.
dgahm Mon, 01/15/2007 - 10:54
  • Blue, 1500 points or more
Kenneth,
You could just start with the default values and adjust as you see what packets are being discarded.
Are you also using CBWFQ?
Posting your configuration might be helpful.
Dave
