Warning message
IPCCX Calling Number ID
Jan 15th, 2007
I have installed IPCCX 4.0 Standard Edition, I want to redirect the calls to diferent menus depending the country code. I need some help to know how to write this part of the script. The variable Calling Number Id is an string and I don't know how to get Country code.
Cheers
Dennis Fogler Mon, 01/15/2007 - 16:34
  • Cisco Employee,
Jorge,
I don't think there is a way to do this is IPCC Express Standard. The reason is because you need to be able to substring the country code from the full ANI.
In IPCCx Enhanced/Premium you can use the "Expressions Editor" under the "Set Variable Object" to substring the country code from the full ANI.
You would enter an expression like
= Set strCountryCode = strANI.substring(x,y)
where x would equal the first position of the country code & y would equal the number of characters.
This would give you a new string varible called "CountryCode".
jorge.rubin Mon, 01/15/2007 - 23:58
I configure
Get call contact info CallingNumber id, then
set to another variable (long) the value on CallingNumber.
End if steps to check the number for exemple:
from 31000000000 to 31999999999 = Netherlands.
I only to do it for one country.
