Warning message
can't configure fa ports
Jan 15th, 2007
I have a 2621 router and flash was erased. Just for practicing purposes, I uploaded IOS version 11.3. I want to upgrade the IOS but I can't ping the TFTP server. I think it is because I could not configure a FA port and I only configured the Loopback port. Is there anyone that can help guide me in what I am doing wrong. I though I could just ocnfigure the Fa interface but it is not giving me the option. I then configured the loopback 0 interface thinking that would do the trick. But I can't ping the tftp server. What am I doing wrong????
Overall Rating: 5 (1 ratings)
sachinraja Mon, 01/15/2007 - 19:08
  • Red, 2250 points or more
Hello ..
did you upload the 11.3 using xmodem ?? after uploading the IOS, are u able to see the FE port on the show run ?? Also check the show version and see if the router has recognized the FE interface.. are these FE built-in interfaces ? how are u connecting the TFTP server ? through a switch ???
Raj
shirwaziri1_2 Tue, 01/16/2007 - 04:59
-I uploaded 11.3 using tftpdnld
-Unable to see FE port in show run
-didn't check show version, i will check it tonight for the Fe port
-Built in Fe interfaces
-yes through a netgear switch
adrian.chadd Mon, 01/15/2007 - 20:01
I don't recall the fastethernet ports being supported on that old an IOS version on the 2600 (they ran 11.3? Wow.)
Just install a recent-ish 12.x IOS image and you should be fine.
royalblues Tue, 01/16/2007 - 08:56
  • Green, 3000 points or more
Just upgrade to the latest 12.2 or 12.3 IOS.
Make sure you have enough flash and Memory requirements to supportthe upgrade.
Narayan
adnan.zafar Wed, 01/17/2007 - 11:43
11.3 does not supports fast ethernet interfaces so you have to switch to 12.*( means some thing)
and do the same thing for IOS update ( like in rom mode use tftpdnld command)
may this help you
