how to send WCS alert?
Answered Question
Jan 16th, 2007
Hi forum,
How do i configure the WCS to send alert to syslog server or send via emails?
Thank you,
paul
Correct Answer by Rob Huffman about 10 years 7 months ago
Hi Paul,
Here is some info to get you started;
Alarm Email Notification
WCS includes a built-in email notification function that can notify network operators when critical alarms occur. Refer to the WCS Monitor > All Alarms > Email Notification page to view the current alarm notification settings.
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a008059c9f5.html#wp1073486
Monitor All Alarms > Email Notification
Use Monitor/Alarms, then from Select a command drop-down list select Email Notification, then click GO to access this page.
This page allows you to view the alarm categories with Critical Alarm email notification enabled and disabled, the current From and To email addresses, and the current SMTP server. This page also allows you to enable and disable email notification for any or all of the Alarm Categories, and allows you to access an Alarm Category email notification setup page.
For every category except Coverage Holes, the alarm severity must be critical to trigger the email. Email notification is available only for Alarms, not for events.
Email Notification Overview
Parameter Description
Enabled Check box; Checked = Email Notification ON, Unchecked = OFF.
Alarm Category The category of Critical alarms that generate an email notification. Click any of the entries in this column to go to the Monitor Email Notification for `' page.
From Any valid Transmitting email address.
To Any valid Receiving email address.
SMTP Server The name or IP address of the SMTP server that transmits the email notifications.
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a00805c546a.html#wp1041196
Note: Non-critical alarms do not generate email notifications.
A WCS administrator currently has no control over which events generate alarms, when they time out, or what severity they are. On the controller, individual types of events can be enabled or disabled (such as management, SNMP, trap controls, etc.).
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a00806b72fe.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 01/17/2007 - 05:56
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
From this doc;
From this doc;
From this doc;
Hope this helps!
Rob
paulnigel Wed, 01/17/2007 - 17:34
Hi Rob,
I must say you are really really helpful.
Thank you very much,
paul
Rob Huffman Thu, 01/18/2007 - 05:22
  • Hall of Fame,
    Founding Member
Hi Paul,
You are very welcome. It is really a pleasure working with such nice people :)
Take care,
Rob
paulnigel Mon, 01/22/2007 - 17:13
Hi Dave,
if you click the alarm category, you can modify the smtp server, from & to settings as well.
Thank you,
paul
Trending Topics - Security & Network
