Warning message
Bridging two routers
Jan 17th, 2007
Curious to know the process on how to bridge two routers. In this case we have a 2821 and a 3600 we need to bridge in a location. The 3600 routes data currently and we're installing the 2821 to service/encrypt VoIP. I can honestly say I have no experience with bridging routers or the commands.
Any assistance would be wonderful. Thank you!
hitesharora Thu, 01/18/2007 - 02:34
You will need to disable 'ip routing' on the routers and enable the bridging protocol on the interfaces which you want to be bridged.
Rgds
tim_mccolgan Thu, 01/18/2007 - 06:43
Thanks Rgds. I'm a little confused still:
If you have the new router, and want to bridge to the existing router, both ends need to have ip routing turned off? How does the data get over the ?T? with it turned off?
Also, any commands would help as well. Thank you again.
flitcraft33 Thu, 01/18/2007 - 11:05
If I understand your question, I think you need to use IRB bridging on two interfaces on each router. you simply use the following config commands, (I have shamelessly used a Cisco provided example here);
bridge IRB
bridge 1 protocol ieee
then add the interfaces you want to bridge traffic to a bridge group.
For instance,
interface Ethernet0
no ip address
no ip directed−broadcast
bridge−group 1
interface Ethernet0
no ip address
bridge−group 1
Will add the1 and 0 to a bridge group.
What's even cooler is that you can actually route to and from the bridge GROUP by giving it an ip address.
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip classless
ip route 10.10.30.0 255.255.255.0 10.10.20.2
!−− This command enables the bridging on this router.
bridge 1 route ip
!−− This command enable bridging as well routing for IP protocol.
Hope this helps.
Dan Sichel
Ponderosa Telephone
