Warning message
Outgoing dial-peer on CME problem
Jan 18th, 2007
Dear all,
I have 2 dial-peer
dial-peer voice 1 pots
destination pattern 9........
port 1/0/0
dial-peer voice 2 pots
destination pattern 9001T
port 1/0/0
When I dial 9xxxxxxxx, it work. But when i dial 9001xxxxxxxx. The call become 9001.....; it go to dial-peer 1.
How can I use dial-peer 2 to make 9001 call.
Overall Rating: 2.5 (2 ratings)
Tony Huynh Thu, 01/18/2007 - 23:18
  • Silver, 250 points or more
The dial-peer hunting algorithm does a digit by digit analysis and will match the first dial-peer that is a possible match. What is the first dial-peer meant to match?
Here are 2 workarounds:
(1) make the first dial-peer the following:
destination pattern 9T
port 1/0/0
(2) or if it is meant for local calls in the US, then you could use the following and thus it won't match dial-peer voice 1 when you dial an international call
destination-pattern 9[2-9]......
port 1/0/0
Hope this helps,
Tony
marahman78 Fri, 01/19/2007 - 21:04
You can use Preference value to set priority for dial peers.
