Ipv6 multicast
Jan 19th, 2007
  • Cisco Employee,
Please see the output of these cmds:
sup3-AB5-mal8v6#sho ipv6 mroute
Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group,
C - Connected, L - Local, I - Received Source Specific Host Report,
P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set,
J - Join SPT
Timers: Uptime/Expires
Interface state: Interface, State
(*, FF1E::1), 20:25:11/never, RP ::, flags: SCJ
Incoming interface: Null
RPF nbr: ::
Immediate Outgoing interface list:
TenGigabitEthernet2/1, Forward, 20:25:11/never
(3005::2, FF1E::1), 01:30:54/00:00:50, flags: SFJT
Incoming interface: TenGigabitEthernet2/5
RPF nbr: 3005::2
Inherited Outgoing interface list:
sup3-AB5-mal8v6#Sho ipv6 pim topology
IP PIM Multicast Topology Table
Entry state: (*/S,G)[RPT/SPT] Protocol Uptime Info
Entry flags: KAT - Keep Alive Timer, AA - Assume Alive, PA - Probe Alive,
RA - Really Alive, LH - Last Hop, DSS - Don't Signal Sources,
RR - Register Received, SR - Sending Registers, E - MSDP External,
DCC - Don't Check Connected
Interface state: Name, Uptime, Fwd, Info
Interface flags: LI - Local Interest, LD - Local Disinterest,
II - Internal Interest, ID - Internal Disinterest,
LH - Last Hop, AS - Assert, AB - Admin Boundary
(*,FF1E::1)
SM UP: 20:25:54 JP: Join(now) Flags: LH
RP: ::
RPF: ,::
Te2/1 20:25:54 fwd LI LH
(3005::2,FF1E::1)
SM SPT UP: 01:31:38 JP: Join(never) Flags: KAT(00:03:12) RA
RPF: TenGigabitEthernet2/5,3005::2*
No interfaces in immediate olist
My question is int t2/1 is joining group ff1e::1 which is being shown correctly in the output of "show ipv6 mroute" but in the output "ipv6 pim toplogy" it says "No interfaces in immediate olist"
Can someone tell why this is so..
Geeta
Harold Ritter Mon, 01/22/2007 - 14:27
  • Cisco Employee,
It is normal for the interface not to show up in the olist of a (S,G) entry in the PIM topology table as per the following documentation excerpt:
"For example, an interface is added to (*,G) entry in PIM topology table upon receipt of an MLD report or PIM (*,G) join message. Similarly, an interface is added to (S,G) entry upon receipt of MLD INCLUDE report for S and G or PIM (S,G) join message. Then PIM installs an (S,G) entry in MRIB with immediate olist (from (S,G)) and inherited olist (from (*,G)). Therefore, the proper forwarding state for a given entry (S,G) can be seen only in the MRIB or the MFIB, not in the PIM topology table."
For a full description of the "show ipv6 pim topology" command:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/ipv6_r/ipv6_15g.htm#wp2068197
Use the "show ipv6 mrib route" or "show ipv6 mfib" to get the right information for the specific (S,G).
Hope this helps,
