dbellaze Fri, 01/19/2007 - 22:22
  • Bronze, 100 points or more
Ethernet is not a point to point link so it does not support PPP encapsulation to participate in multilink. The only exception is PPPoE but that has some other requirements not just PPP.
I don't think you can bond these links with MLP.
Daniel
royalblues Sat, 01/20/2007 - 13:28
  • Green, 3000 points or more
You cannot do PPP multilink on an ethernet interface as ethernet is a multiaccess network.
HTH, rate if it does
Narayan
alessandro.veras Sat, 01/20/2007 - 16:02
A multilink association between a ethernet interface and a serial interface seens to be impossible.
But you can do a kind of multilink association over ethernet interfaces. This kind of "feature" is called EtherChannel. With it you can group ethernet interfaces in a load balance scheme.
See more informations in http://www.cisco.com/warp/public/473/4.html
