ping fails to hosts behind the VPN router
Jan 20th, 2007
We have site to site VPN. using IPSEC/GRE. Centralised headend with several remote sites. One of the remote sites is connected but when I ping 347 Bytes or more to anything beyond the headend router i get less than 1% response. If I ping the headend router or other remote sites all is normal, any size is fine.
It was fine a few days ago, not aware of any config changes that might have caused it.
Other remote sites don't have this issue.
Any idea's anyone, got me a bit stumped.
spremkumar Mon, 01/22/2007 - 23:52
  • Red, 2250 points or more
Can you check out the mtu size specified under the interfaces through which your packet is getting traversed ?
Hope you can verify the config of this spoke with other spokes which are working..
regds
