Warning message
FWSM
sachinraja Mon, 01/22/2007 - 23:02
  • Red, 2250 points or more
Hello aksher
from the 6500 chassis, you can use the session command to enter to the appropriate chassis...
session 4, where 4 is the module number... you need to have the correct modules on the correct slots !!!!
Hope this helps..all the best..
Raj
Patrick Iseli Tue, 01/23/2007 - 06:42
  • Gold, 750 points or more
Refernce:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_2_3/fwsm_cfg/sysmgmt.htm
Session into the FWSM using the command appropriate for your switch operating system:
?Cisco IOS software
Router# session slot number processor 1
?Catalyst operating system software
Console> (enable) session module_number
sincerely
Patrick
