copy IOS from one switch to another
Jan 23rd, 2007
I have a major delima on my hands. I am trying to update the IOS on a bunch of 6509E's at a remote site. The problem is that I am having a great deal of difficulty getting the image loaded using tftp across the WAN. The session keeps timing out. I was able to get one switch updated but have really struggled since then. The question is, can I copy the IOS from the one I succeeded with to others at that site? That would eliminate the time out problem. If so, how do I set that up?
pciaccio Tue, 01/23/2007 - 06:55
  • Silver, 250 points or more
Place the image onto a flash card and move the card from switch to switch copying it to them one by one....Good Luck...
glen.grant Tue, 01/23/2007 - 07:10
  • Purple, 4500 points or more
Set up the working 6500 with the image you want to use as a tftp server and then just copy it as you would from any other tftp server . Use the copy tftp command to copy it to the other boxes.
