Warning message
connect fews WRV200 to a PIX515e ( v7) as remote access
Jan 23rd, 2007
I would like to connect some WRV200 to a 515E in v7 as remote access mode, because remote site didn't have fixed ip address. I beleave that lan to lan work but not sure as remte access.
thank in advance
irisrios Mon, 01/29/2007 - 12:03
  • Silver, 250 points or more
Check whether the encryption algorithm are licensed one or not. For eg if you are using 3DES with Restricted license could be reason for your problem. So,check the licensing option.
