Warning message
Sh run or conf t not working on router
Jan 23rd, 2007
We have a router that when trying to show the running configuration or enter configuration mode or write memory, it does not repsond. I have tried clearing the lines but they will not clear. Is there a way to fix this without rebooting the router.
Richard Burts Tue, 01/23/2007 - 11:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Thomas
The first suggestion would be to clarify what privilege level you are at when you attempt these commands? The output of show privilege would be helpful for this.
Also it would help us understand the symptoms if you would clarify what happens when you attempt these commands. Do you get an error message? If so what is the error message?
Rick
thomuff Tue, 01/23/2007 - 12:15
Current privilege level is 15
I hit enter and it does not return anything.
NO error message.
It actually came back after a couple of minutes
5d-swan Tue, 01/23/2007 - 13:56
A long delay is normally if it is trying to retrieve authorisation. Are you running RADIUS or TACACS?
If you are, try typing "show aaa servers" and see if the "Author" stats show an increasing number of timeouts/failures.
Good luck :-)
alessandro.veras Tue, 01/23/2007 - 14:30
Hi thomuff.
Did you try to reload the router?
I already see this kind of problem happens, and it goes back to normal after reload.
Bye.
smothuku Tue, 01/23/2007 - 20:57
  • Silver, 250 points or more
Hi ,
I already experienced same kind of p[roblem and i checked the cpu utilization using show process memory and sh process cpu history.
Check the utilization of cpu and find out which process is using more cpu and it is better check the buffer using sh buffers cmd.
The said problem occurs when cpu utilization is more during that time.
Hope it helps you.I think you may not see problem after reloading the router.
Suggestion : check how much memory is being used by the i/o devices.
