Public IP cisco 870 or cisco 1812
Jan 24th, 2007
Hi all,
i would like to setup 2 public ip address on wan interface (cisco 870 wan int. = fa4). The first IP for NAT overloading from user VLAN and the second IP for email server and web server. Is there any chance for binding two IP on interface fa4?
Thanks for your reply.
Overall Rating: 5 (1 ratings)
network.king Wed, 01/24/2007 - 02:49
  • Silver, 250 points or more
Instead of having a secondry address on the WAN , create a loopback address and do a pat with that for ur email server and webserver .
Hope this helps
regards
vanesh k
spremkumar Fri, 01/26/2007 - 03:05
  • Red, 2250 points or more
In addition to Vanesh's comments make sure that you have your routing set at the SP end for your loopback ip via the WAN ip otherwise the reachability wont be there to the secondary ip address..
regds
