DB Connection hung up after CSM failover
Hi there,
i have the following problem in my active /standby csm-s configuration :
i established a connection between a server and a database. after a forced failover the connections are still established on the standby csm-s. there are no new connections on the active csm-s. On server side the connection hung up...
Have you any idea ??
Best regards Dirk
PS: there is no connection replication configured
Gilles Dufour Wed, 01/31/2007 - 04:27
  • Cisco Employee,
without connection replication I don't see how this can work.
The traffic will be sent to the active which will drop it because there is no connection in its database.
The client should detect the problem [if the application has a recovery mechanism] and close the connection to open a new one.
Gilles.
