IPCC 4.0 and TTS Realspeak 4.0
Jan 24th, 2007
I installed TTS software and configured MRCP TTS Provider on IPCC succesfully (the provider is "In Service" and the server is "Reachable"); but the command "Create TTS Prompt" doesn't work on IPCC script.
Any idea about what is wrong?
Thanks in advance.
thomas.chen Tue, 01/30/2007 - 11:06
  • Silver, 250 points or more
- In the Application, have you set up the correct Language on the JTAPI Trigger.
- The correct port to be used is 554, according to the administrator guide, page 424
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_0/english/administ/crs401ag.pdf
Try:
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/prod_bulletin0900aecd8033f6c0.html
Stefano Amici Thu, 02/01/2007 - 01:17
Are you able to work properly IPCC 4.0 and Realspeak 4.0.12? Have you modify the xml configuration file?
I already readed these documents but didn't solve my problem.
Stefano Amici Thu, 02/01/2007 - 08:54
Realspeak server log file.
The error is "Message too large", but i send to Realspeak only one word.
Any ideas?
