802.11Q vlans on 2811
Answered Question
hi everyone. I'm trying to configure a brand new 2811 to route packets between vlans. the question is: is it possible to do it without the switching hwic? the seller said it was possible, but I'm not so confident in this. will I have to buy the 4 port hwic integrated switch module to do it?
thanks
Correct Answer by mbilgrav about 10 years 6 months ago
Yes you can !
I have done so several time on all C28xx platforms, and older routers aswell.
you need to do subinterfaces before you can add the encapsulation:
(Sample output from real router C2801)
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 10.10.10.10 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 10.10.20.20 255.255.255.0
show ip route:
10.0.0.0/24 is subnetted, 2 subnets
C 10.10.10.0 is directly connected, FastEthernet0/1.10
C 10.10.20.0 is directly connected, FastEthernet0/1.20
Overall Rating: 4.5 (2 ratings)
mheusinger Thu, 01/25/2007 - 06:31
  • Green, 3000 points or more
This is possible without the switching module. The configuration details and some examples can be found at "Configuring Routing Between VLANs"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080684bf5.html
Basically you configure one sub-interface per VLAN with a separate IP subnet f.e. on a FastEthernet. After this you can enable IP routing on those interfaces like on any physical interface.
Hope this helps! Please use the rating system.
Regards, Martin
e-dennington Thu, 01/25/2007 - 06:54
Here is my config for one of my remote sites. the router is a 2821 running 12.3(14). I don't think the version of a particular IOS should prevent you from using this feature though.
interface GigabitEthernet0/0.1
description Data VLAN
encapsulation dot1Q 1 native
ip address 172.16.1.254 255.255.255.0
ip helper-address 172.20.62.129
no snmp trap link-status
interface GigabitEthernet0/0.3
description Phone VLAN
encapsulation dot1Q 3
ip address 172.16.3.254 255.255.255.0
interface GigabitEthernet0/0.30
description Call Manager VLAN
encapsulation dot1Q 30
ip address 172.16.30.6 255.255.255.248
Where 1,3 and 30 are vlans on the switch attached to gig0/0.
Correct Answer
mbilgrav Thu, 01/25/2007 - 07:02
Yes you can !
no ip address
duplex auto
speed auto
show ip route:
mheusinger Thu, 01/25/2007 - 07:09
like the two authors above I would be surprised. Still it might be something we do not know yet. Can you please post a show version and the configuration you would like to activate, but is rejected?
Regards, Martin
glen.grant Thu, 01/25/2007 - 10:09
  • Purple, 4500 points or more
Have to have at least IP plus code to run this otherwise it should work without a problem . The enterpriseservices should support it , did you put the encapsulation command on the subinterface ? I have run this on old 3640 without a problem and even trunked a bridged interface across it and it worked fine .
