insert pause when dialing
Jan 25th, 2007
I saw that if you put a "," in some componen in CRA Editor it is translated in a pause of 1 second. example #1234,5678 it dials 1234 then wait 1 second, then dials 5678.
How can i obtain the same functionality on jtapi class?
Tommer Catlin Thu, 01/25/2007 - 15:38
  • Green, 3000 points or more
I thought I had read that CallManager does not recognize pauses. Unless you are using some sort of IPCC script.
luisSDMEX Thu, 01/25/2007 - 15:46
I found how to generate DTMF tones whit the metod generateDtmf(String) of the interface MediaTerminalConnection. Can some one tellme how i can use it
luisSDMEX Thu, 01/25/2007 - 15:48
