one fastethernet link down in channel-group
Jan 27th, 2007
Hi, everyone.
I have a problem when I configure two 3550-emi switch. On both 3550 switch, I have configured FEC link on fastethernet port 0/3 and 0/4. But only link is up at the same time.
The log say: %EC-5-L3DONTBNDL2: Fa0/4 suspended: incompatible partner port with Fa0/3; but the configuration on both switch and both 4 ports are same as below, I don't know why?
interface Port-channel44
no switchport
ip address 3.3.3.3 255.255.255.0
duplex full
interface FastEthernet0/3
description BSW2 0/3 to BSW1 0/3
no switchport
no ip address
duplex full
speed 100
channel-group 44 mode desirable
interface FastEthernet0/4
description BSW1 0/4 to BSW2 0/4
no switchport
no ip address
duplex full
speed 100
I have try Layer 3 FEC and Layer 2 FEC(with trunk link), but the result is same.
Anyone can help me?
With Best Regards.
Tao
hetao Sat, 01/27/2007 - 23:36
The layer 2 configuration is as below:
sw1:
interface Port-channel33
switchport trunk native vlan 951
switchport mode trunk
no ip address
end
description BSW1 0/3 to BSW2 0/3
no ip address
duplex full
speed 100
channel-group 33 mode desirable
end
no ip address
duplex full
speed 100
end
sw2
no ip address
end
no ip address
duplex full
speed 100
no ip address
duplex full
speed 100
But the result is same, only fas0/3 is up, line protocol in fas0/4 is down, log say:
Mar 1 14:55:49.212: %EC-5-L3DONTBNDL2: Fa0/4 suspended: incompatible partner port with Fa0/3
*Mar 1 14:55:57.188: %EC-5-L3DONTBNDL2: Fa0/4 suspended: incompatible partner port with Fa0/3
*Mar 1 14:56:27.196: %SM-4-BADEVENT: Event 'link_down' is invalid for the current state 'link_down': pm_port 0/3
-Traceback= 34A88C 32F000 2F8954 345CE8 346358 1C6440
*Mar 1 14:56:33.632: %EC-5-L3DONTBNDL2: Fa0/4 suspended: incompatible partner port with Fa0/3
*Mar 1 14:56:36.328: %EC-5-L3DONTBNDL2: Fa0/4 suspended: incompatible partner port with Fa0/3
anyone can help me?
Very thanks
Tao
hetao Sat, 01/27/2007 - 23:44
when I finished the configuration as above, line protocaol on fa0/3 is up, but line protocaol on fas 0/4 is down.
Then i shutdown the fas0/3, line protocol on fas0/4 is up immediately.
why?
mahmoodmkl Sun, 01/28/2007 - 00:43
  • Gold, 750 points or more
Can u try this.Dnot create the port-channel interface as when u assign the ports in a switch to form a channel it will be automatically created.
Mahmood
hetao Sun, 01/28/2007 - 05:39
Thanks, Mood.
I have try it again. And I found when i change channel-group mode to on from desirable, it is ok. But when i change to desirable again, same result. But port-channel interface is up always.
Who can give some advise. In production network, should I make it mode on or desirable?
glen.grant Sun, 01/28/2007 - 08:21
  • Purple, 4500 points or more
Try adding the non-silent command at the end of the port channel statement for all interfaces and see what happens . Also for all your attaching ports make sure you have added the "switchport" command to make it a non routed port for a lyer 2 etherchannel.
channel-group 33 mode desirable non-silent
hagirebench Mon, 01/29/2007 - 01:15
Tao,
try this setting the channel-group mode on switch1 to "desirable" and the channel-group mode on the switch2 to "auto"
Switch1:
Switch2:
channel-group 33 mode auto
rgds.
ben
