Unity Express AutoAttendant Script
Jan 28th, 2007
Is it possible to mimic the behavior of Unity in Unity Express by the script to do the following and if so does anyone have an example that I can look at for guidance?
I wanted to of course check for holidays and open hours, that I have from the samples.
But if its business hours I want it go like this. If you know your parties extension you can dial it at anytime (ext. 37XX and 38XX) if you would like to dial by name press 1, if you would like the latest information on X press 2, if you woould like to speak to the operator press 0 or remain on the line and someone will be with you momentarily.
Thanks for any assistance that you can provide on this.
