how to decrypt username's password on the router?
Jan 29th, 2007
Hi, Just would like to know what tool I can use to decrypt the username which use for the console vty login as the previous admin left without the password.
Thanks.
royalblues Tue, 01/30/2007 - 00:28
  • Green, 3000 points or more
Friend,
There are lot of tools available on the net to crack the password of the cisco router.
One thing to remember though is you will be able to crack only the level 7 encrypted password and the enable secret.
With the VTY password you will be able to get into the user mode but if you dont remeber the enable secret password you cant get into the privelege mode. Password recovery would be the only option in this case
HTH, rate if it does
Narayan
mheusinger Tue, 01/30/2007 - 00:54
Besides the afore mentioned tools, which will ONLY decode the "encryption" indicated by 7 in the command, the best bet would be to perform a password recovery. The relevant procedures are described in "Password Recovery Procedures"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
You will need physical access to the router and it involves a reload, i.e. a network outage.
Hope this helps!
Regards, Martin
cindylee27 Tue, 01/30/2007 - 00:36
Hi Sprem,
This is useful! :D thanks..
but i managed to decrypt level 7 only.
But i could not get through enable secret 5 ?
h0w can i do that?
Thanks again!
spremkumar Tue, 01/30/2007 - 00:38
  • Red, 2250 points or more
Hi Cindy
As mentioned by Naryan in his post you need to use password recovery procedure to reset the enable secret 5 password which is otherwise not possible with any kinda tools as of now..
regds
mheusinger Tue, 01/30/2007 - 02:19
the "5" indicates MD5 encryption, which - to my knowledge - can not be decrypted to date.
So password recovery is your only option.
Regards, Martin
