ACL Problem
Jan 30th, 2007
Hi Guys,
My issues is this:
I have a home office router and a core router. The following is the config. I'm using crypto maps to create it. But there seems to be an issue with the ACLS. I can ping both public IP address but after that, nothing. Any help is great. Any good ACL troubleshooting methods?
Main Router to Home office Router:
crypto isakmp policy 1
authentication pre-share
group 2
lifetime 3600
crypto isakmp key RODONOHU-VPN address 213.94.219.249
crypto ipsec transform-set 60GMAC esp-3des esp-md5-hmac
crypto map COGENT_VPN 60 ipsec-isakmp
description RODONOHU-HOME-TEST
set peer 213.94.219.249
set transform-set 60GMAC
match address RODONOHUE_HOME
ip route 172.17.25.16 255.255.255.240 66.28.244.17 name RobODonohueHomeTest
ip route 213.94.219.249 255.255.255.255 66.28.244.17 name RODONOHU-TUNNEL
ip access-list extended RODONOHUE_HOME
permit ip host 66.28.244.18 host 213.94.219.249
permit ip 172.16.0.0 0.0.255.255 172.17.25.16 0.0.0.15
permit ip 172.17.0.0 0.0.255.255 172.17.25.16 0.0.0.15
permit ip 192.168.0.0 0.0.255.255 172.17.25.16 0.0.0.15
permit ip 192.206.209.0 0.0.0.255 172.17.25.16 0.0.0.15
deny ip any any log
Home Office Router
encr 3des
hash md5
group 2
lifetime 3600
crypto isakmp key RODONOHU-VPN address 66.28.244.18
set peer 66.28.244.18
match address Crypto_ACL
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended Crypto_ACL
permit ip host 213.94.219.249 host 66.28.244.18
permit ip 172.17.25.16 0.0.0.15 172.16.0.0 0.0.255.255
permit ip 172.17.25.16 0.0.0.15 172.17.0.0 0.0.255.255
permit ip 172.17.25.16 0.0.0.15 192.168.0.0 0.0.255.255
permit ip 172.17.25.16 0.0.0.15 192.206.209.0 0.0.0.255
permit ip host 213.94.219.249 host 66.28.244.17
Jon Marshall Tue, 01/30/2007 - 02:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Robert
Could you send the full configs minus any sensitive info. What youy have sent looks alright but i suspect there may be some NAT issues going on.
Jon
rodonohu1 Tue, 01/30/2007 - 02:24
Sure thing John,
Thanks for looking at this.
Rob.
Jon Marshall Tue, 01/30/2007 - 10:27
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Robert
Still sifting through 7206 config :-). Couple of questions
1) Do the VPN setups for RConway & PKearney work ?. These seem to be setup the same as yours.
2) When you try and connect from home how far does the VPN negotiation get, if anywhere.
3) When you say you can access the peer ip addresses with ping have you confirmed this is bringing up the VPN tunnel or is it just going out in cleartext.
The only thing i did notice which is why i aksed 1) is that you have a route not only for your home public ip address but also for your home subnet. This should not be needed on the 7206 as the crypto map access-list should see this as interesting traffic and know it has to be sent down a VPN tunnel. But if the others are working then i guess it makes no difference.
Jon
rodonohu1 Tue, 01/30/2007 - 10:52
Hi Jon,
To answer:
1) The Rconway one worked but it has since been removed so i can't test. I set up the Pkearney one last week and have the same problem as my own one.
2) When i connect from home, the Dialer interface comes up and I can ping the peer address. but how do i verify that the VPN tunnel is up? what debug commands do I need? There is no explicit tunnel created like in the other ones where I use BGP routing and a gre tunnel. I'd do all these the same as that only for two users have wireless routers that don't support BGP.
Do you think I should take out the static route altogether?
sundar.palaniappan Tue, 01/30/2007 - 10:55
  • Green, 3000 points or more
Looks like you have mismatched isakmp policies on the peering routers. Your ISAKMP SA is probably not established and you can verify that by doing 'show crypto isakmp sa'. The default isakmp encryption is DES & hash is SHA and that's what you are using on the core router. Can you remove the hash & encryption from the home office router.
On the Home Office Router:
no encr 3des
no hash md5
If you are still having issues, can you post the output of 'show crypto isakmp policy' from both routers.
Sundar
rodonohu1 Tue, 01/30/2007 - 11:19
I will try this but I have other Home office routers using the same set up with "Policy 1" but they can route. They were using BGP but the router I'm trying to configure this using static route and access lists.
Still no luck.
Jon Marshall Tue, 01/30/2007 - 13:07
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Robert / Sundar
Sundar, there is actually an isakmp policy on the core router that matches but it's just not included in the original post. It's isakmp policy 4 and it should be picked up i would have thought.
I'm still not sure about the route for the remote subnet. Sundar, do you know if this would stop it working ?
Robert - it wouldn't do any harm to temporarily remove the route to see what happens.
If you could also run the commands Sundar sent - best run them on your home router rather than the 7206, there's a lot going on with that router :-)
Jon
rodonohu1 Tue, 01/30/2007 - 16:05
Hi guys,
I've removed the route on the core router and also made the checks and changes to the policy on the home office but still no luck:
See output below from the "sh crypto policy"
Output:
RODONOHU-HOME#sh crypto isakmp policy
Global IKE policy
Protection suite of priority 1
encryption algorithm: Three key triple DES
hash algorithm: Message Digest 5
authentication method: Pre-Shared Key
Diffie-Hellman group: #2 (1024 bit)
lifetime: 3600 seconds, no volume limit
Default protection suite
encryption algorithm: DES - Data Encryption Standard (56 bit keys).
hash algorithm: Secure Hash Standard
authentication method: Rivest-Shamir-Adleman Signature
Diffie-Hellman group: #1 (768 bit)
lifetime: 86400 seconds, no volume limit
RODONOHU-HOME#
Global IKE policy
Any reason why this wouldn't work? is there an easier way of doing it? Normally I'd use Bgp but its not support on the IOS for the HO. What is set up should work, thats what is bugging me.
Jon Marshall Tue, 01/30/2007 - 23:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
From the configs i can't see a huge lot wrong with what you have. Can you try these commands on your home router when you try to connect
1) debug crypto isa
2) debug crpyto ipsec
3) sh crypto isa sa
4) sh crypto ipsec sa
This should give us an idea of how far it is getting
Jon
rodonohu1 Wed, 01/31/2007 - 01:39
I'll check it out.
Just a thought - where do I apply the COGENT_VPN map on the 7206 seeing that i'm not using a tunnel. Is there an interface I apply it to?
Jon Marshall Wed, 01/31/2007 - 03:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
I must have missed that. it will need to applied on the interface with 62.88.x.x address on your 7206 (sorry i've shredded the config now). If it isn't applied it definitely won't work.
Jon
rodonohu1 Wed, 01/31/2007 - 03:32
sorry I checked it again there. its there on the interface alright. just skipped it. AHH this thing is frustrating.!
rodonohu1 Wed, 01/31/2007 - 14:50
Anyone have a look at the updated info i supplied for this issue? It seems to be an issue with the Crypto map not saying up.
See Below:
Sending 5, 100-byte ICMP Echos to 66.28.244.18, timeout is 2 seconds:
Feb 2 08:03:51.203: ISAKMP: received ke message (1/1)
Feb 2 08:03:51.203: ISAKMP: set new node 0 to QM_IDLE
Feb 2 08:03:51.203: ISAKMP (0:1): sitting IDLE. Starting QM immediately (QM_IDLE )
Feb 2 08:03:51.203: ISAKMP (0:1): beginning Quick Mode exchange, M-ID of -572399601
Feb 2 08:03:51.215: ISAKMP (0:1): sending packet to 66.28.244.18 my_port 500 peer_port 500 (I) QM_IDLE
Feb 2 08:03:51.215: ISAKMP (0:1): Node -572399601, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
Feb 2 08:03:51.215: ISAKMP (0:1): Old State = IKE_QM_READY New State = IKE_QM_I_QM1
Feb 2 08:03:51.583: ISAKMP (0:1): received packet from 66.28.244.18 dport 500 sport 500 Global (I) QM_IDLE
Feb 2 08:03:51.595: ISAKMP (0:1): processing HASH payload. message ID = -572399601
Feb 2 08:03:51.595: ISAKMP (0:1): processing SA payload. message ID = -572399601
Feb 2 08:03:51.595: ISAKMP (0:1): Checking IPSec proposal 1
Feb 2 08:03:51.595: ISAKMP: transform 1, ESP_3DES
Feb 2 08:03:51.595: ISAKMP: attributes in transform:
Feb 2 08:03:51.595: ISAKMP: encaps is 1 (Tunnel)
Feb 2 08:03:51.595: ISAKMP: SA life type in seconds
Feb 2 08:03:51.595: ISAKMP: SA life duration (basic) of 3600
Feb 2 08:03:51.595: ISAKMP: SA life type in kilobytes
Feb 2 08:03:51.595: ISAKMP: SA life duration (VPI) of 0x0 0x46 0x50 0x0
Feb 2 08:03:51.595: ISAKMP: authenticator is HMAC-MD5
Feb 2 08:03:51.599: ISAKMP (0:1): atts are acceptable.
Feb 2 08:03:51.599: ISAKMP (0:1): processing NONCE payload. message ID = -572399601
Feb 2 08:03:51.599: ISAKMP (0:1): processing ID payload. message ID = -572399601
Feb 2 08:03:51.647: ISAKMP (0:1): Creating IPSec SAs
Feb 2 08:03:51.647: inbound SA from 66.28.244.18 to 213.94.219.249 (f/i) 0/ 0
(proxy 6.!!!!
Success rate is 80 percent (4/5), round-trip min/avg/max = 108/111/112 ms
RODONOHU-HOME#6.28.244.18 to 213.94.219.249)
Feb 2 08:03:51.647: has spi 0x4D8354B6 and conn_id 202 and flags 2
Feb 2 08:03:51.647: lifetime of 3600 seconds
Feb 2 08:03:51.647: lifetime of 4608000 kilobytes
Feb 2 08:03:51.647: has client flags 0x0
Feb 2 08:03:51.647: outbound SA from 213.94.219.249 to 66.28.244.18 (f/i) 0/ 0 (proxy 213.94.219.249 to 66.28.244.18 )
Feb 2 08:03:51.647: has spi 873654110 and conn_id 203 and flags A
Feb 2 08:03:51.651: ISAKMP (0:1): sending packet to 66.28.244.18 my_port 500 peer_port 500 (I) QM_IDLE
Feb 2 08:03:51.655: ISAKMP (0:1): deleting node -572399601 error FALSE reason ""
Feb 2 08:03:51.655: ISAKMP (0:1): Node -572399601, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
Feb 2 08:03:51.655: ISAKMP (0:1): Old State = IKE_QM_I_QM1 New State = IKE_QM_PHASE2_COMPLETE
Jon Marshall Thu, 02/01/2007 - 00:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rob
Sorry i didn't look at this yesterday - had a bit of a load balancing crisis.
The interesting but from the debugs is
local ident (addr/mask/prot/port): (172.17.25.16/255.255.255.240/0/0)
remote ident (addr/mask/prot/port): (192.206.209.0/255.255.255.0/0/0)
current_peer: 66.28.244.18:500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 41, #pkts encrypt: 41, #pkts digest 41
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 1, #recv errors 0
Can you identify what traffic generated this ie. what machine you were using from home and which machine you were trying to contact. Cleary there was traffic being sent down the tunnel but nothing coming back.
Jon
rodonohu1 Thu, 02/01/2007 - 01:12
No problem at all.
I just tried to ping a server on the other end. it just timed out. Could numbered ACLs be better to use than Named? I know probably not but i'm clutching at straws. the machine from home was just a desktop.
Are there any other debugs or show commands i could use to show more details?
Jon Marshall Thu, 02/01/2007 - 02:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
No i don't think it's going to make any difference what type of acl you use.
Can you confirm that if you try and contact a server at work from your home subnet that the debugging showed nothing ?
What i would like is the following
1) Turn on debug crypto isa
2) turn on debug crypto ipsec
Try to connect from home to a server at work. As it is trying to connect
1) sh crypto isa sa
2) sh crypto ipsec sa
I don't normally add in the peer IP addresses to the crypto maps when i do site-to-site VPNs but it should be okay.
Apologies if you have already done this but it is a bit unclear from the debugging.
Jon
Jon Marshall Thu, 02/01/2007 - 13:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
Sorry to be a pain but i don't think i explained myself properly. We know that the tunnel comes up when you ping the 7206 router public ip address from home. But what i'm trying to establish is what happens if you try and ping one of the servers from home but not after you have pinged the 7206 public ip address.
If you ping the public ip address of the 7206 then it will bring up the tunnel. What i want to know is what happens when there is no tunnel and you try and ping one of the servers/hosts at work. If you have debugging on you should see some activity.
If not then we can narrow it down to a problem with your home router recognising the traffic needs to be sent down the VPN.
Jon
rodonohu1 Thu, 02/01/2007 - 14:18
Hi Jon
I can safely say I'm the pain so far. Thanks again for looking at this. I'm attaching my results.looks like nothing is happening when i ping the server. Note, i did have bgp set up on this router and it worked with the 7206 fine. Reason i'm testing this with the ACL is that i need to set it up in the same way for another cisco router that doesn't support Bgb.
Have a look at the doc and let me know,
Cheers
rtanner Thu, 02/01/2007 - 17:04
Sorry, I'll just stop lurking for a sec...
My understanding is that the access-list applied to the crypto map is used to determine what is encrypted over the tunnel. If so, I would question the entry with the local-peer/remote peer in the named access -list you match. Can you try removing this entry?
rodonohu1 Mon, 02/05/2007 - 13:50
This ACL issue will Kill me. To clarify, I'm trying to set up a IPsec tunnel and put an acl on each end to allow traffic pass from one subnet to the others. at this stage i can ping either end of the tunnel but no further. please see below: Any help or ideas would be greatly appreciated:
The core router config:
7206 side of Tunnel
crypto isakmp policy 4
encr 3des
hash md5
group 2
lifetime 3600
crypto isakmp key xxx address 213.x.219.249
match address 160
access-list 160 permit ip 172.16.0.0 0.0.255.255 172.17.25.16 0.0.0.15
access-list 160 permit ip 172.17.0.0 0.0.255.255 172.17.25.16 0.0.0.15
access-list 160 permit ip 192.168.0.0 0.0.255.255 172.17.25.16 0.0.0.15
access-list 160 permit ip 192.206.209.0 0.0.0.255 172.17.25.16 0.0.0.15
The 1700 side is attached.
rtanner Mon, 02/05/2007 - 18:06
so, we know:
the crypto maps establish the association.
traffic goes one way at least ( based on jon's observations)
Given it was working with BGP, and not knowing your network, is there a route back to the home network (from the server) - since you have moved to a static environment from a dynamic one...
Jon Marshall Tue, 02/06/2007 - 00:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rob
Sorry i haven't responded, i was being a but dense. This thread now takes 2 pages but i didn't realise so i kept checking it only to see my message at the end of page one. Bit dense i know :-)
Unfortunately i couldn't open your .doc file. Based on your observations
1) Did the tunnel come up at all when you tried to ping the server
2) Did you see any debugging output on your home router when the tunnel came up.
3) It is certainly worth checking out the routing as suggested by other poster.
Jon
rodonohu1 Tue, 02/06/2007 - 01:43
No problem Jon. To answer your questions:
- when i tried to ping the server from my home router, nothing happened. I had debugging on but nothing was outputted to the screen. I can ping the tunnel end but no internal address.
- Following on from rtanners post - There is a static router from the 7206 to the home office router as follows:
but not one for my internal network. should I add one for as follows:
Jon Marshall Tue, 02/06/2007 - 01:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
if nothing happened it does sound like your home router does not recognise the traffic as needing to go down the VPN.
Could you let me know where you are pinging from and what you are pinging in terms of IP addresses.
From within your corporate network if you do a traceroute to 172.17.25.16 does it go to the 7206 router ?.
If not then yes you will need to add a route but not to 66.28.244.17. You need to add a route within your coporate network that sends traffic to the INTERNAL interface of your 7206. The VPN config will take care of it from there.
Jon
rodonohu1 Tue, 02/06/2007 - 04:23
Jon,
When I traceroute on the 7206 i get the following:
1 192.168.31.205 0 msec 0 msec 0 msec
2 192.168.142.118 4 msec 0 msec 0 msec
3 192.168.0.254 92 msec 96 msec 96 msec
4 172.17.2.17 [AS 65203] 100 msec 96 msec 96 msec
5 172.17.4.4 [AS 65203] 92 msec 92 msec 96 msec
6 * * *
7 * * *
this is because on anohter router we have the 172.17.25.0 subnet advertised using BGP. So I think I need to add the static route to ensure that the traffic goes out statically. The internal interface has an address of 192.168.31.206 - is this the correct interface? I see other static routes pointing to the 66.28.244.17 address with i guess is the other end of the external interface. Why not this?
Jon Marshall Tue, 02/06/2007 - 04:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
You usually only have to get the traffic to the device that is doing the VPN. The crypto map access-list is used to determine where to send the traffic.
So the packet arrives at the 7206 and it consults the crypto maps, finds a match, encrypts it and routes it down the VPN tunnel. I've never had to configure a static route on the VPN device for the remote device.
Having said that what might be happening in your network is that all the statics routes are done on the 7206 and so you would need to point it somewhere.
What i generally do is step one router back, so in your case the router that connects to the 7206 from the inside. Add the static there and then redistribute it into your IGP if that is hwo your internal network routing works.
However this may not apply in your network so if you are applying the route on the 7206 you should make the next hop 66.28.244.17 as you say.
Jon
rodonohu1 Tue, 02/06/2007 - 04:43
Thanks - i'll give it a go with the static route on the 7206. will let you know later in the day how i get on.
Cheers,
Rob.
rodonohu1 Tue, 02/06/2007 - 07:40
I've applied the static ip address on the 7206 route. I set up debugging on the home router and tried to ping the following address from my desktop 192.169.176.132. The following is the debugging that came out of this. Before when i tried this, it didnt produce any output.
Anything from that?
Jon Marshall Tue, 02/06/2007 - 07:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rob
Is that a typo - should the IP address be 192.168.176.132 ?
Anyway, looks from the debugging like you now are creating an IPSEC tunnel. What does the output of "sh crypto ipsec sa" on your router show.
I'm assuming the ping didn't work though. Is that correct ?
Jon
rodonohu1 Tue, 02/06/2007 - 08:04
Yes - it was a typo. fat fingers! And correct, i tried the ping but no response. I did a sh crypto ipsec sa and the result didn't seem different to the one before but foolishly i didn't take a print of it and i'm now away from the set up. I can do it tonight and send it over then. Anything I can check on the 7206side?
The ACL on the home router is now:
access-list 160 permit ip 172.17.25.16 0.0.0.15 172.16.0.0 0.0.255.255
access-list 160 permit ip 172.17.25.16 0.0.0.15 172.17.0.0 0.0.255.255
access-list 160 permit ip 172.17.25.16 0.0.0.15 192.168.0.0 0.0.255.255
access-list 160 permit ip 172.17.25.16 0.0.0.15 192.206.209.0 0.0.0.255
dialer-list 1 protocol ip permit
Should i include a line to permit the public ip traffic back? I'm guessing its covered in the map peers.
franklaszlo Tue, 02/06/2007 - 13:21
Hi Jon,
to be honest I did not read through the whole story just the beginning and the and, so I am sorry if I say something you already had known.
I have the same scenario but with a 831 SOHO router at the BO and a 1841 at HQ.
What I guess, is that the acl in the crypto-map which should initiate tunnel setup does not get hit. You have to configure it so that your remote LAN destination address range get a match on it. Here is a short exceprt of my config :
crypto ipsec transform-set tset esp-3des
crypto map cmap 100 ipsec-isakmp
set peer public_ip_of_the_peer
set transform-set tset
match address vpnacl
ip access-list extended vpnacl
permit ip local_subnet remote_subnet
When you ping a host in the remote subnet, it will match the ACL which will in turn bring up the tunnel with the remote peer.
And one more thing, if it applies : you will have to set up NAT by using route-maps, otherwise it will not work.
I hope it helps.
Laszlo
Jon Marshall Tue, 02/06/2007 - 13:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Laszlo
No problem with joining in, the more the merrier :-).
There was a problem getting the remote router to recognise the interesting traffic but i think we are past that now.
Could you explain what you mean about having to setup NAT or it won't work. I don't think Rob is actually Natting the traffic at all from his home PC.
Jon
rodonohu1 Tue, 02/06/2007 - 13:31
Hi Laszlo.
it does look like you have a similar set up. Can you give me an example of the NAT to be used?
and is it only to be appiled at the HQ router?
franklaszlo Tue, 02/06/2007 - 14:18
my network setup is :
BO LAN : 10.1.10.0/24 - BO Router(831) -- ADSL -----INet-----LL-HQ Router(1841)--HQ LAN 10.1.1.0/24 and 10.1.18.0/24
This is the relevant config of the BO router :
crypto key pubkey-chain rsa
named-key vpn_router_hostname encryption
address HQRouterPublicIP
key-string
xxx
quit
identity profile default
template Virtual-Template1
crypto isakmp policy 100
encr 3des
authentication rsa-encr
group 2
crypto isakmp identity hostname
crypto isakmp keepalive 30
set peer HQRouterPublicIP
interface Ethernet0
ip address 10.1.10.1 255.255.255.0
ip helper-address 10.1.1.9
ip helper-address 10.1.1.20
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1300
dot1x port-control auto
dot1x reauthentication
dot1x max-req 10
no cdp enable
interface Ethernet1
no ip address
no ip unreachables
no ip proxy-arp
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Loopback0
ip access-group inetonly in
ip access-group inetonly out
ip nat inside
interface Dialer1
mtu 1400
ip address negotiated
ip access-group incoming_traffic in
ip access-group outgoing_traffic out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect firewall out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password xxx
ppp pap sent-username xxx
ppp ipcp dns request
crypto map cmap
ip classless
ip nat inside source route-map dontnatlocal interface Dialer1 overload
ip access-list extended incoming_traffic
permit tcp any host BORouterPublicIP eq 22
permit udp host HQRouterPublicIP host BORouterPublicIP eq isakmp
permit esp host HQRouterPublicIP host BORouterPublicIP
ip access-list extended inetonly
deny ip any 10.0.0.0 0.255.255.255
permit ip any any
ip access-list extended outgoing_traffic
permit udp host BORouterPublicIP host HQRouterPublicIP eq isakmp
permit esp host BORouterPublicIP host HQRouterPublicIP
permit ip 10.1.10.0 0.0.0.255 10.1.1.0 0.0.0.255
permit ip 10.1.10.0 0.0.0.255 10.1.18.0 0.0.0.255
ip access-list extended what_to_nat
deny ip 10.1.10.0 0.0.0.255 10.1.1.0 0.0.0.255
deny ip 10.1.10.0 0.0.0.255 10.1.18.0 0.0.0.255
permit ip 10.1.10.0 0.0.0.255 any
route-map dontnatlocal permit 10
match ip address what_to_nat
Hope it helps,
Laszlo
rodonohu1 Wed, 02/07/2007 - 01:21
Thanks Laszlo. I'll be sure to see if i can config mine the same. do you have the patching config on the HQ router? is that natted as well? Interesting stuff. I appreciate it.
franklaszlo Wed, 02/07/2007 - 01:43
yes, the HQ router is also Natted, here is its crypto config :
ip host BORouterHostName BORouterPublicIP
named-key BORouterHostName encryption
address BORouterPublicIP
key-string
xxxxxxx
quit
crypto isakmp policy 80
encr 3des
group 2
crypto ipsec transform-set vpntransform esp-3des
crypto map vpnmap 150 ipsec-isakmp
set peer BORouterPublicIP
set transform-set vpntransform
match address vpnacl010
interface Serial0/0/0
ip address xxx
ip access-group 101 in
ip access-group 102 out
ip nat outside
crypto map vpnmap
ip route 0.0.0.0 0.0.0.0 ISP_Gateway_address
ip route 10.1.1.0 255.255.255.0 Internal_Router
ip route 10.1.18.0 255.255.255.0 Internal_Router
ip nat inside source route-map what_to_nat interface Serial0/0/0 overload
ip access-list extended natlocal
deny ip 10.1.1.0 0.0.0.255 10.1.8.0 0.0.7.255
deny ip 10.1.18.0 0.0.0.255 10.1.8.0 0.0.7.255
permit ip 10.1.1.0 0.0.0.255 any
permit ip 10.1.18.0 0.0.0.255 any
ip access-list extended vpnacl010
permit ip 10.1.1.0 0.0.0.255 10.1.10.0 0.0.0.255
permit ip 10.1.18.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 101 permit udp host BORouterPublicIP host HQRouterPublicIP eq isakmp
access-list 101 permit esp host BORouterPublicIP host HQRouterPublicIP
route-map what_to_nat permit 10
match ip address natlocal
Laszlo
franklaszlo Wed, 02/07/2007 - 00:53
I could not find one of my posts from yesterday, so I try again :
You should not both route a specific traffic and mask it with the crypto-acl at the same time. I think this :
and
deny ip any any log
If you try to ping a host located in the remote subnet 172.17.25.16/28 then this traffic gets routed instead of beeing put into the tunnel, because the router first checks the routing table. Look at this article : http://www.cisco.com/warp/public/556/5.html
Laszlo
