отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Объявления
Добро пожаловать в Сообщество Технической поддержки Cisco. Мы рады получить обратную связь .
Community Member
Transcoder
Здравствуйте.
Помогите разобраться почему не рабоатет transcoder. CUCM 10 через sip транк подключен к Cisco 2921. К 2921 по sip подключен провайдер.
Конфигурация 2921
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 CUCM_IP
ipv4 PROVIDER_IP
allow-connections sip to sip
sccp local GigabitEthernet0/0.211
sccp ccm CUCM_IP identifier 121 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 121 priority 1
associate ccm 122 priority 2
associate profile 1 register c2921_buz_tcdr
associate profile 2 register c2921_buz_conf
associate profile 3 register c2921_buz_mtp
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
codec g722-64
maximum sessions 8
associate application SCCP
dial-peer voice 1000 voip
description *** Inbound DP for Ergress Call ***
translation-profile incoming ErgressCall
session protocol sipv2
session target sip-server
incoming called-number .
voice-class sip bind control source-interface GigabitEthernet0/0.211
voice-class sip bind media source-interface GigabitEthernet0/0.211
dtmf-relay cisco-rtp rtp-nte sip-notify
codec g711ulaw
dial-peer voice 9000 voip
description *** Outbound DP to CUCM->External ***
destination-pattern .T
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay h245-alphanumeric h245-signal sip-notify sip-info cisco-rtp rtp-nte
codec g711ulaw
c2921_buz#sh sccp
SCCP Admin State: UP
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: CUCM_IP, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
На CUCM транскодер также в состоянии Registered.
У телефона через Pool настроен MRGL, в котором указан этот транскодер.
В debug ccsip mess:
Sent:
SIP/2.0 503 Service Unavailable
Warning: 399 CUBE_IP "Transcoder Not Configured"
Server: Cisco-SIPGateway/IOS-15.4.3.M2
Reason: Q.850;cause=47
Что не так?
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Владислав,
Владислав,
Вы настроили транскодер правильно, просто согласование кодеков в данном случае происходит не на CUCM, а на CUBE, поэтому он просто не будет задействован.
Чтобы задействовался настроенный транскодер, можно сделать тестовый телефон, засунуть его в тестовый регион А, для SIP транка регион B. Между регионами настроить ограничение в 8kbit/s (g729), а на CUBE в диал пирах прописать только g711alaw (чтобы удовлетворить условия провайдера).
По идее в этом случае у Вас будет пытаться задействоваться транскодер, так как codec mismatch будет уже не на CUBE, а на CUCM.
По поводу транскодера для CUBE можно прочитать здесь:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115018-configure-cube-lti.html
Kirill
7 ОТВЕТ.
Владислав,
Владислав,
Скорее всего Вам не нужен транскодер на CUCM,  наши телефоны спокойно передают речь в как в g711, так и в g729.
У Вас на dial-peer настроен кодек g711ulaw,а  со стороны провайдера может приходит g729, тогда транскодер понадобится не CUCM, а CUBE и регистрировать его надо именно там: application CUBE, не application SCCP.
Надо смотреть всю сигнализацию с шлюза, но я бы посоветовал вместо одного кодека на dial-peer прописать профайл с несколькими кодеками и посмотреть, что получится.
Kirill
Community Member
Внутри используется ulaw, а
Внутри используется ulaw, а провайдер обязательно требует alaw.
честно говоря не видел конфигурации application cube, во всех примерах sccp. я думал трансклдер так и настраивается, а можно пример настройки cube?
Добрый день,
Добрый день,
CUCM (или IP-телефоны) поддерживает как ulaw, так и alaw. По идее все что вам нужно, это сменить на диал-пирах кодек на g711alaw и транскодер не понадобится.
Еще CUCM умеет с помощью software MTP (IPVMS service) менять режим компандирования кодека g711 между alaw <---> ulaw.
Community Member
с проблемой стыка думаю
с проблемой стыка думаю разберусь. Меня сейчас больше интересует именно работоспособность транскодера, настраивал всегда по инструкциям, но только сейчас понял что ни разу не проверял. Как правильно настроить транскодер?
Владислав,
Владислав,
Kirill
Community Member
Добавил еще один dsp profile
Добавил еще один dsp profile и все заработало.
dspfarm profile 4 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
codec g722-64
maximum sessions 8
associate application CUBE
Еще пара вопросов. Можно настроить transcode universal, что дает это unuversal, не нашел описания?
И на счет того что телефоны поддерживают alaw, не понял как проверить.
Во входящем диал пире поставил
codec g711alaw
И в сторону CUCM сразу идет отбой
SIP/2.0 488 Not Acceptable Media
alaw как-то надо на телефоне конфигурировать?
Universal transcoder - это
Universal transcoder - это более "мощное" устройство :)
Раньше обычный транскодер на мог делать преобразование из одного кодека в тот же самый и звонок рвался. К примеру, стоит MTP required, а звонок в одном кодеке.
На телефонах конфигурировать кодеки не надо, нужно смотреть трейсы, из-за чего идет отбой.
Kirill
182
Просмотры
Полезный материал
7
Ответы
СоздатьДля создания публикации, пожалуйста в систему
