отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Объявления
Добро пожаловать в Сообщество Технической поддержки Cisco. Мы рады получить обратную связь .
802.1q транк между Catalyst 3560 и AIR-AP1121G
Совсем голову сломал
Есть точка доступа AIR-AP1121G. Хочу соединить ее с Catalyst 3560 802.1 транком.
На AIR-AP1121G
interface FastEthernet0.1
 encapsulation dot1Q 1 native
 bridge-group 1
interface FastEthernet0.2
 encapsulation dot1Q 2
 bridge-group 2
interface BVI1
 ip address 192.168.152.201 255.255.255.0
interface BVI2
 ip address 192.168.150.201 255.255.255.0
sh int fa0.2
FastEthernet0.2 is up, line protocol is up
  Hardware is PowerPCElvis Ethernet, address is 001d.4584.c50c (bia 001d.4584.c50c)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,  reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  2.
На Catalyst
interface FastEthernet0/29
 switchport trunk allowed vlan 1-3
 switchport mode trunk
interface Vlan1
 ip address 192.168.152.242 255.255.255.0
interface Vlan2
 ip address 192.168.150.242 255.255.255.0
sh int fa0/29 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 1-3
Pruning VLANs Enabled: NONE
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Транк вроде поднялся. VLAN в состоянии active. Из сети 192.168.152.0/24 адрес 192.168.150.242 пингуется нормально.
А вот между Точкой доступа и каталистом работает только native.
CiscoAp-service#ping 192.168.152.242
Sending 5, 100-byte ICMP Echos to 192.168.152.242, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
а вот так уже не работает
CiscoAp-service#ping 192.168.150.242
Sending 5, 100-byte ICMP Echos to 192.168.150.242, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Куда смотреть? Что делать?
  • Маршрутизация и коммутация (Routing and Switching)
2 ОТВЕТ.
Честно говоря, автономные
Честно говоря, автономные точки не настраивал, но... Сделайте на свитче show spanning-tree int fa0/29. Может, всё проще.
Интересно и необычно.Видимо
Видимо это какая-то особенность данной точки доступа.
Что обнаружено.
1) Транк работает нормально.
2) MAC адреса резолвятся правильно.
3) Wireshark показал, что пинги от источника уходят (как от точки так и от коммутатора), а вот ответов нету.
4) Клиент точки отрабатывает нормально, попадает в нужный vlan. На пинги с клиента коммутатор отвечает, точка нет.
Может кому поможет.
41
Просмотры
Полезный материал
Ответы
Не удалось отобразить этот виджет.
