отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Объявления
Добро пожаловать в Сообщество Технической поддержки Cisco. Мы рады получить обратную связь .
pptp ospf
имеются cisco 1841
проблема в следующем клиенты которые цеплятся по pptp  не могут попасть в филиалы
Building configuration...
Current configuration : 9855 bytes
! Last configuration change at 10:54:01 Msk Wed Dec 25 2013 by user
! NVRAM config last updated at 10:54:06 Msk Wed Dec 25 2013 by user
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname 1841_dm
boot-start-marker
boot system flash c1841-ipbase-mz.124-24.T3.bin
boot system flash c1841-spservicesk9-mz.124-23.bin
boot system flash c1841-adventerprisek9-mz.151-2.T1.bin
boot-end-marker
logging buffered 4096
aaa new-model
aaa authentication ppp vpn local
aaa session-id common
clock timezone Msk 3 0
clock summer-time MSD recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
ip source-route
ip dhcp pool pptp-users
    network 10.0.6.0 255.255.255.0
    dns-server 8.8.8.8
    default-router 10.0.6.254
ip cef
no ip bootp server
ip domain name cisco
ip name-server 91.123.16.120
ip name-server 91.189.240.28
no ipv6 cef
ntp max-associations 1
vpdn enable
vpdn-group TEST
  ! Default PPTP VPDN group
  accept-dialin
   protocol pptp
   virtual-template 11
  l2tp tunnel timeout no-session 15
password encryption aes
crypto pki trustpoint TP-self-signed-1479394571
  enrollment selfsigned
  subject-name cn=IOS-Self-Signed-Certificate-1479394571
  revocation-check none
crypto pki certificate chain TP-self-signed-1479394571
  certificate self-signed 01
           quit
license udi pid CISCO1841 sn FCZ1217930L
archive
  log config
   hidekeys
object-group network ssh
  range 10.0.6.1 10.0.6.50
redundancy
ip tcp synwait-time 10
no ip ftp passive
ip ssh rsa keypair-name drushba
ip ssh version 2
ip ssh pubkey-chain
   username user
    key-hash ssh-rsa EDCFD4131035332649FEE45D1D32253A
   quit
crypto isakmp policy 1
  encr 3des
  hash md5
  authentication pre-share
crypto isakmp policy 2
  encr 3des
  hash md5
crypto isakmp policy 3
  encr aes 256
  group 2
crypto isakmp key 6 pass address 0.0.0.0 0.0.0.0
crypto isakmp profile ciscocp-ike-profile-1
! This profile is incomplete (no match identity statement)
crypto ipsec security-association lifetime kilobytes 50000
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set tr-3des esp-3des
crypto ipsec transform-set user esp-aes 256 esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
  set transform-set user
  set isakmp-profile ciscocp-ike-profile-1
crypto ipsec profile prof_tun
  set transform-set tr-3des
interface Tunnel1
   bandwidth 30
  ip address 10.0.77.25 255.255.255.252
  ip ospf 100 area 10
  tunnel source FastEthernet0/0/0
  tunnel destination 84.51.76.x
interface Tunnel3
  bandwidth 30
  ip address 10.0.76.25 255.255.255.252
  ip virtual-reassembly in
  ip route-cache policy
  ip tcp adjust-mss 1024
  ip ospf 100 area 10
  tunnel mode ipsec ipv4
  tunnel destination 85.26.153.x
  tunnel protection ipsec profile prof_tun
interface Tunnel4
  bandwidth 30
  ip address 10.0.75.25 255.255.255.252
  ip ospf 100 area 10
  tunnel destination 83.167.101.x
interface Tunnel6
  bandwidth 30
  ip address 10.0.73.25 255.255.255.252
  ip ospf cost 100
  ip ospf 100 area 10
  tunnel destination 109.206.132.x
interface Tunnel8
  bandwidth 30
  ip address 10.0.80.26 255.255.255.252
  ip ospf 100 area 10
  tunnel destination 178.217.96.x
interface Tunnel9
  bandwidth 30
  ip address 10.0.81.25 255.255.255.252
  tunnel destination 85.21.96.x
interface Tunnel12
  bandwidth 30
  ip address 10.0.84.25 255.255.255.252
  ip ospf cost 200
  ip ospf 100 area 10
  tunnel destination 95.128.247.x
interface FastEthernet0/0
  no ip address
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip flow ingress
  shutdown
  duplex auto
  speed auto
  no mop enabled
interface FastEthernet0/1
  description $ES_LAN$
  ip address 10.10.10.2 255.255.255.0 secondary
  ip address 172.16.0.20 255.255.0.0
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip flow ingress
  ip nat inside
  ip policy route-map clear-df
  duplex auto
  speed auto
  no mop enabled
interface FastEthernet0/0/0
  ip address 91.216.x.x 255.255.255.0
  ip dns view-group 8.8.8.8
  ip nat outside
  duplex auto
  speed auto
  no mop enabled
interface Virtual-Template1 type tunnel
  no ip address
  tunnel protection ipsec profile CiscoCP_Profile1
interface Virtual-Template11
  ip unnumbered FastEthernet0/1
  peer default ip address dhcp-pool pptp-users
  ppp encrypt mppe auto required
  ppp authentication pap chap ms-chap
router ospf 100
  router-id 172.16.0.20
  network 10.0.6.0 0.0.0.255 area 10
  network 172.16.0.0 0.0.255.255 area 10
ip default-gateway 91.216.x.x
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool GLOBALPOOL 91.216.x.x 91.216.x.x netmask 255.255.255.0
ip nat inside source list 2 pool GLOBALPOOL overload
ip route 0.0.0.0 0.0.0.0 91.216.x.x
ip route 10.0.100.0 255.255.255.0 10.0.81.26
ip route 172.1.0.0 255.255.255.0 10.0.77.26
ip sla schedule 2 start-time pending
logging esm config
logging facility local0
logging source-interface FastEthernet0/1
no cdp run
route-map clear-df permit 10
  set ip df 0
control-plane
line con 0
line aux 0
line vty 0 4
  exec-timeout 60 0
  privilege level 15
  transport input ssh
scheduler allocate 4000 1000
ntp server 195.239.199.18 version 2
end
show  ip route
S*    0.0.0.0/0 [1/0] via 91.216.x.x
       10.0.0.0/8 is variably subnetted, 25 subnets, 3 masks
O        10.0.3.0/24 [110/3334] via 10.0.80.25, 1d07h, Tunnel8
                      [110/3334] via 10.0.76.26, 1w0d, Tunnel3
O        10.0.4.0/24 [110/201] via 10.0.73.26, 02:21:56, Tunnel6
C        10.0.6.3/32 is directly connected, Virtual-Access3
O        10.0.8.0/24 [110/101] via 10.0.73.26, 02:31:49, Tunnel6
O        10.0.9.0/24 [110/101] via 10.0.73.26, 02:31:49, Tunnel6
O        10.0.70.24/30 [110/200] via 10.0.73.26, 02:21:56, Tunnel6
C        10.0.73.24/30 is directly connected, Tunnel6
L        10.0.73.25/32 is directly connected, Tunnel6
C        10.0.75.24/30 is directly connected, Tunnel4
L        10.0.75.25/32 is directly connected, Tunnel4
C        10.0.76.24/30 is directly connected, Tunnel3
L        10.0.76.25/32 is directly connected, Tunnel3
C        10.0.77.24/30 is directly connected, Tunnel1
L        10.0.77.25/32 is directly connected, Tunnel1
C        10.0.80.24/30 is directly connected, Tunnel8
L        10.0.80.26/32 is directly connected, Tunnel8
C        10.0.81.24/30 is directly connected, Tunnel9
L        10.0.81.25/32 is directly connected, Tunnel9
O        10.0.82.24/30 [110/3433] via 10.0.73.26, 02:31:49, Tunnel6
C        10.0.84.24/30 is directly connected, Tunnel12
L        10.0.84.25/32 is directly connected, Tunnel12
O        10.0.85.24/30 [110/300] via 10.0.73.26, 02:21:45, Tunnel6
S        10.0.100.0/24 [1/0] via 10.0.81.26
C        10.10.10.0/24 is directly connected, FastEthernet0/1
L        10.10.10.2/32 is directly connected, FastEthernet0/1
       91.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        91.216.48.0/24 is directly connected, FastEthernet0/0/0
L        91.216.48.3/32 is directly connected, FastEthernet0/0/0
       172.1.0.0/24 is subnetted, 1 subnets
S        172.1.0.0 [1/0] via 10.0.77.26
       172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.0.0/16 is directly connected, FastEthernet0/1
L        172.16.0.20/32 is directly connected, FastEthernet0/1
O     192.168.0.0/24 [110/201] via 10.0.73.26, 02:21:56, Tunnel6
O     196.192.0.0/23 [110/3334] via 10.0.80.25, 1d07h, Tunnel8
traceroute  с клиента заканчивается на хопе 172.16.0.20
8 ОТВЕТ.
pptp ospf
А до филиалов как идти? Через туннели? Устройства с той стороны каждого туннеля имеют маршруты до хостов из 10.0.6.0/24?
pptp ospf
да через тунели
я анансирую маршрут через ospf
router ospf 100
вот пример конфигурации филиала
Current configuration : 5172 bytes
! Last configuration change at 19:19:56 MSK Tue Dec 10 2013 by user
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone MSK 3 0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip name-server 193.201.231.1
ip name-server 193.201.230.1
no ipv6 cef
vpdn enable
license udi pid CISCO1841 sn FCZ1218118N
redundancy
ip ssh rsa keypair-name tpso
encr 3des
hash md5
crypto isakmp key pass address 0.0.0.0 0.0.0.0
set security-association lifetime kilobytes 50000
set security-association lifetime seconds 86400
interface Tunnel3
bandwidth 30
ip address 10.0.76.26 255.255.255.252
ip ospf 100 area 10
tunnel source 85.26.153.131
tunnel destination 91.216.x.x
interface Tunnel8
  bandwidth 30
ip address 10.0.80.25 255.255.255.252
ip ospf 100 area 10
interface Tunnel10
  bandwidth 30
ip address 10.0.82.25 255.255.255.252
ip ospf 100 area 10
interface Tunnel11
description ostrovtsy to arctel
bandwidth 30
ip address 10.0.83.26 255.255.255.252
ip ospf 100 area 10
shutdown
description megafon
ip address 85.26.153.x 255.255.255.240
duplex auto
speed auto
description local net
ip address 10.0.3.2 255.255.255.0 secondary
ip address 196.192.1.95 255.255.254.0
duplex auto
speed auto
description art telecom
ip address 178.217.96.x 255.255.255.240
duplex auto
speed auto
router ospf 100
network 10.0.3.0 0.0.0.255 area 10
network 196.192.0.0 0.0.0.255 area 10
network 196.192.1.0 0.0.0.255 area 10
ip default-gateway 85.26.153.x
no ip http server
ip route 0.0.0.0 0.0.0.0 85.26.153.x
i
ip sla schedule 2 life forever start-time now
logging esm config
logging history debugging
control-plane
line con 0
line aux 0
line vty 0 4
access-class 101 in
exec-timeout 120 0
privilege level 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp server 95.167.164.118 version 2
end
pptp ospf
Так в филиале есть маршрут до pptp клиента? Сделайте например show ip route 10.0.6.3 (если он все еще подцеплен, иначе какой-нибудь другой).
И давайте работать по конкретным адресам. До какого адреса нет доступа с клиента?
pptp ospf
странно дейсчтвительно нет маршрута на cisco которая стоит a филиале  на сеть 10.0.6.0/24
хотя сеть 10.0.6.0 /24 анансирую  с cisco которая стоит в центральном оффисе
router ospf 100
Re: pptp ospf
"network 10.0.6.0 0.0.0.255 area 10" не анонсирует сеть 10.0.6.0/24, а ищет интерфейсы по этой маске и анонсирует их сети.
Сделайте в OSPF redistribute connected с роут-мапом на 10.0.6.0/24 ge 32, или даже без роут-мапа.
pptp ospf
сдела
router ospf 100
redistribute connected route-map vpn
access-list 10 permit 10.0.6.0 0.0.0.255
set ip df 0
route-map vpn permit 10
match ip address 10
результат  без изменений
pptp ospf
Так, извиняюсь, конечно же "redistribute connected subnets route-map vpn".
pptp ospf
спасибо  большое все заработало
375
Просмотры
Полезный материал
8
Ответы
СоздатьДля создания публикации, пожалуйста в систему
