告知
シスコ サポート コミュニティへようこそ!あなたの ご意見 をお聞かせください。
Problems with Cisco Voice Gateway 2811
I have a cisco 2811 router with 8 ports FXS which functions as SIP voice gateway, it is registered to a SIP SERVER,
but I can only make calls to telephone and not cell phone, and receive calls from the PSTN either.
Please could help me.
Router#sh run
Building configuration...
Current configuration : 2578 bytes
! Last configuration change at 18:31:40 UTC Thu Jan 26 2012
! NVRAM config last updated at 18:33:22 UTC Thu Jan 26 2012
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
ip name-server 172.24.106.6
voice-card 0
no dspfarm
voice service voip
srtp
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  rel1xx disable
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
interface FastEthernet0/0
no ip address
load-interval 30
duplex full
speed 100
interface FastEthernet0/0.2709
encapsulation dot1Q 2709
ip address 10.32.160.178 255.255.255.252
no snmp trap link-status
interface FastEthernet0/1
ip address 10.32.248.253 255.255.255.252
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.32.160.177
no ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
station-id number 5116604421
voice-port 0/3/1
station-id number 5116604423
dial-peer voice 4421 voip
preference 1
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target ipv4:172.24.106.6
dtmf-relay sip-notify
no vad
dial-peer voice 604421 pots
preference 1
destination-pattern 5116604421
incoming called-number 5116604421
port 0/3/0
prefix 5116604421
authentication username 5116604421 password 0253550A5D505F75181C58 realm 172.24.106.6
dial-peer voice 604423 pots
preference 1
destination-pattern 5116604423
incoming called-number 5116604423
port 0/3/1
prefix 5116604423
authentication username 5116604423 password 014657550D5D565B751E1D realm 172.24.106.6
dial-peer voice 4423 voip
preference 1
voice-class codec 1
no vad
gateway
sip-ua
no redirection
retry register 10
timers connect 100
timers refer 300
timers register 100
registrar ipv4:172.24.106.6 expires 3600
sip-server ipv4:172.24.106.6
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Router#
Router#show sip-ua register status
Line          peer           expires(sec)  registered
5116604421    604421           376           yes
5116604423    604423           382           yes
Router#
1 件の返信
Hello Usuario,
Thank you for visiting Cisco Support Community Japan.
We are sorry that this community is intended to
communicate in Japanese language and for English users,
the main English Support Community should suit better.
https://supportforums.cisco.com/community/netpro/collaboration-voice-video
Please allow us for taking your time, but please post your
message in above the discussion forum so that your
question has more chance to get resolved soon.
Thanks and Regards,
1082
返信
