Community Member
3350 3A red led in diagnostic card
l have a 3A red led in diagnostic card in a NAC 3350.
i can´t find information about troubleshooting.
Operational function is not affected. but a red led never is a good signal.
I want find how to diagnose if problem is DIMM or slot. how may i do it?
in linux just exist free -m command to view memory status but no more.
Can you help me please.
Everyone's tags (1)
Figure 7 Cisco NAC-3350 Front
Figure 7 Cisco NAC-3350 Front Panel LEDs/Buttons
http://www.cisco.com/c/en/us/td/docs/security/nac/appliance/installation_guide/hardware/45hwqsg.html#wp34536
Power On/Standby button and system power LED
Green = System is on
Amber = System is shut down, but power is still applied
Off = Power cord is not attached, power supply failure has occurred, no power supplies are installed; facility power is not available, or disconnected power button cable
UID button/LED
Blue = Identification is activated
Flashing blue = System is being managed remotely
Off = Identification is deactivated
Internal health LED
Green = System health is normal
Amber = System health is degraded. (To identify the component in a degraded state, refer to "HP Systems Insight Display and LEDs.")
Red = System health is critical. (To identify the component in a critical state, refer to "HP Systems Insight Display and LEDs.")
Off = System health is normal when in standby mode
External health LED (power supply)
Green = Power supply health is normal
Amber = Power redundancy failure occurred
Off = Power supply health is normal when in standby mode
NIC 1 (eth0) link/activity LED
Green = Network link exists
Flashing green = Network link and activity exist
Off = No link to network exists
If power is off, the front panel LED is not active. For status, view the rear panel LED for the RJ-45 connector (Figure 9).
6
NIC 2 (eth1) link/activity LED
Community Member
That table had already found.
That table had already found. Throw hence the problem is in the 3A memory, but again I ask you:
How I can determine if the problem is physical or DIMM slot?
Thanks in advance
Community Member
Do you have any comment ???I
I want to run something in NAC to check the status of the DIMMs.
4 days ago I answered your comment and so far I have not RECEIVED more product reviews
thanks in addvance
38
