3850 with ISE - 802.1x Pending Deletion
David Santos
Guys,
After a search in the docs I couldn´t find what is this status "Pending Deletion" in the "Blocked on" line.
sw#sh authentication sessions int gi 1/0/12 det
            Interface:  GigabitEthernet1/0/12
               IIF-ID:  0xC6E48000006674
          MAC Address:  [omitted]
         IPv6 Address:  Unknown
         IPv4 Address:  10.7.0.76
            User-Name:  [omitted]
               Status:  Authorized
               Domain:  DATA
       Oper host mode:  single-host
     Oper control dir:  both
      Session timeout:  N/A
    Common Session ID:  0AFE0AF00022940F55761E56
      Acct Session ID:  0x002443D3
               Handle:  0xF90003C2
       Current Policy:  (Unnamed Policy)
          Blocked On:  Pending Deletion
Method status list:
       Method           State
       dot1x            Authc Success
       mab              Stopped
can someone explain me what is this?
2 Accepted Solutions
phosawyer
For anyone looking for info on this problem. A bug has been reported:
https://tools.cisco.com/bugsearch/bug/CSCur26195
Rolf Fischer
Level 9
Level 9
Today I found this old post when I was troubleshooting a similar problem with a MAB client.
In this particular case I was able to solve the problem by using the "forced" option of "clear authentication sessions mac".
switch#show auth sessions interface gi1/0/32 details
Interface: GigabitEthernet1/0/32
MAC Address: 0200.00cc.0f93
IPv4 Address: 192.168.240.151
User-Name: 02-00-00-CC-0F-93
Status: Authorized
Domain: DATA
Oper host mode: multi-auth
Current Policy: POLICY_Gi1/0/32
SM Accounting Feature
switc#clear auth sessions mac 0200.00cc.0f93 ?
forced Forcefully clear auth session. Use this as last resort
switch#clear auth sessions mac 0200.00cc.0f93 forced
11 Replies 11
David Santos
What i´ve found so far:
so in this case,
D - Awaiting Deletion—Session deletion has
begun. One or more asynchronous actions are
currently in progress (either retrieving
accounting data from the platform or deleting
the IIF ID).
what does this mean? What is the IIF ID?
Anyone?
David,
I havent found any information on this myself and have not worked with a 3850 for any radius authentication. This will take some time on my end to get an answer for you. In the meantime and if this is an issue you may want to open a TAC case to see if an engineer can shed some light on this.
Tarik Admani
*Please rate helpful posts*
Tarik,
I´m going to upgrade the sw to the last version.
Give me a couple of days to test this...
Hi David,
I am experiencing exactly same problem with 3850 and ISE 1.2 - everything works correctly with other switch types.
It worked some time but last few days this problem appeared.
Have you found the solution? My IOS version is 03.02.02.SE. I will try to upgrade tonight and hope it will work - otherwise I am going to open TAC case.
Jan
Jan,
so far the client haven´t told me anything new concerning this subject. I think that the upgrade to 03.03.01SE resolved the problem.
Upgrade your Sw first and then tell me if it solved this problem.
DS
Upgrade to version 03.03.02SE seems to solve this issue. It works now, but it worked before and than stopped, so I will confirm later.
mlinder01
Hi David,
Do you still have this problem? Today i got an email from a customer which has this problem too... he has Cisco 3650 with IOS XE 03.03.02SE.
Manuel
Nothing so far. I´ve got everything up and running.
DS
I know this is an old thread, but I thought I'd mention that I've got a stack on 3.3.3SE with the same "stuck in deletion" problem for only one MAC address. We've had a wide range of dot1x/mab issues with these 3850's, so it's not too surprising that we're adding another one to the pile. I'm wondering if it wasn't your upgrade that fixed it, but rather the reboot required for the upgrade that did. We're getting ready to upgrade to 3.6.1 this weekend to resolve another dot1x issue we've been working on with Cisco TAC and developers. Did either of you ever see this issue come back?
phosawyer
Rolf Fischer
Level 9
Level 9
Status: Authorized
Domain: DATA
