802.1x and ACS
when implementig a 802.1x with a cisco ACS is necesary to work with certificates or it can just work with username and password?
Re: 802.1x and ACS
It can work either way based on the EAP method selected.
Re: 802.1x and ACS
But if I wanto to enable "PEAP" is says that a certificate must be installed, do you have a good guide to implemente 802.1x ACS 4.1?
Re: 802.1x and ACS
Re: 802.1x and ACS
But it works with certificates, I just wan to validate with username and password, is that possible?
194
