Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
802.1x dynamic vlan assignment using ACS 4.2
we have 10 switches 2960 configured with 802.1x authentication against ACS server 4.2.
we have 2 vlans configured on the switches for administrator and endusers. the end user vlan id is 10 and the administartor vlan is is 100.
we need to apply the following scenario, if the enduser PC - that is connected to vlan 10 - has an issue and the administrator will login to the PC with the administrator account to fix that issue, the switch should dynamically reconfigure the port with the administrator vlan ( 100 ) .
is the above scenario doable using dot1x with the ACS server?
waiting your replies
Mohamed
605
