802.1x EAP-TLS Problem
I am doing a 802.1x EAP-TLS test by using C2950, Windows 2000 IAS Radius, and Windows 200 CA. After setting up the aaa on the switch, the client always get a deauthorized port status as you can see it on the bottom line 4 debugging output. Also, I have installed the user certificate on the client and set automatic request certificate on the Win2K AD for computer certificate. Attached are the switch config and debug output and hope you guys can give me an advise. Thanks!
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
aaa new-model
aaa authentication dot1x default group radius
ip subnet-zero
vtp mode transparent
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
switchport mode access
no ip address
spanning-tree portfast
interface FastEthernet0/3
no ip address
dot1x port-control auto
interface Vlan1
ip address 10.10.10.50 255.255.255.0
no ip route-cache
radius-server host 10.10.10.1 auth-port 1812 acct-port 1813
radius-server retransmit 3
radius-server key cisco
end
04:30:37: dot1x-core(Fa0/3): EAPOL pkt in
04:30:37: dot1x-core(Fa0/3): 00:00:39:3F:AA:D1 sent EAPOL type=0, EAP code=2, id=1
04:30:37: dot1x-authsm(Fa0/3): state CONNECTING, event INPUT, arg 0x80B9B7CC
04:30:37: dot1x-authsm(Fa0/3): state AUTHENTICATING, event ENTRY, arg 0x80B9B7CC
04:30:37: dot1x-besm(Fa0/3): state IDLE, event INPUT, arg 0x80B9B7CC
04:30:37: dot1x-reauthsm(Fa0/3): state INITIALIZE, event INPUT, arg 0x80B9B7CC
04:30:37: dot1x-core(Fa0/3): control event
04:30:37: dot1x-authsm(Fa0/3): state AUTHENTICATING, event CONTROL, arg 0x0
04:30:37: dot1x-besm(Fa0/3): state IDLE, event CONTROL, arg 0x0
04:30:37: dot1x-besm(Fa0/3): state RESPONSE, event ENTRY, arg 0x0
04:30:37: dot1x-reauthsm(Fa0/3): state INITIALIZE, event CONTROL, arg 0x0
04:30:37: dot1x-reauthsm(Fa0/3): reauth timer stopped
04:30:37: dot1x-besm(Fa0/3): state RESPONSE, event CONTROL, arg 0x0
04:30:37: dot1x-backend(Fa0/3): [3] starting aaa sequence
04:30:37: dot1x-backend(Fa0/3): [3] relaying EAP data from supplicant
04:30:37: dot1x-backend(Fa0/3): [3] starting login
04:30:37: dot1x-backend(Fa0/3): [3] login user host/bptec11.ad.test.com, client ID 00-00-39-3F-AA-D1
04:30:37: dot1x-backend(Fa0/3): [3] start_login returned GETDATA
04:30:37: dot1x-core(Fa0/3): RADIUS reply (2) received
04:30:37: dot1x-authsm(Fa0/3): state AUTHENTICATING, event SERVER_REPLY, arg 0x2
04:30:37: dot1x-besm(Fa0/3): state RESPONSE, event SERVER_REPLY, arg 0x2
04:30:37: dot1x-besm(Fa0/3): state REQUEST, event ENTRY, arg 0x2
04:30:37: dot1x-core(Fa0/3): send EAPOL type=0, EAP code=1, id=2
04:30:37: dot1x-reauthsm(Fa0/3): state INITIALIZE, event SERVER_REPLY, arg 0x2
04:30:41: dot1x-core(Fa0/3): EAPOL pkt in
04:30:41: dot1x-core(Fa0/3): 00:00:39:3F:AA:D1 sent EAPOL type=0, EAP code=2, id=2
04:30:41: dot1x-authsm(Fa0/3): state AUTHENTICATING, event INPUT, arg 0x80B9B7CC
04:30:41: dot1x-besm(Fa0/3): state REQUEST, event INPUT, arg 0x80B9B7CC
04:30:41: dot1x-besm(Fa0/3): state RESPONSE, event ENTRY, arg 0x80B9B7CC
04:30:41: dot1x-reauthsm(Fa0/3): state INITIALIZE, event INPUT, arg 0x80B9B7CC
04:30:41: dot1x-core(Fa0/3): control event
04:30:41: dot1x-authsm(Fa0/3): state AUTHENTICATING, event CONTROL, arg 0x0
04:30:41: dot1x-besm(Fa0/3): state RESPONSE, event CONTROL, arg 0x0
04:30:41: dot1x-reauthsm(Fa0/3): state INITIALIZE, event CONTROL, arg 0x0
04:30:41: dot1x-reauthsm(Fa0/3): reauth timer stopped
04:30:41: dot1x-backend(Fa0/3): [3] relaying EAP data from supplicant
04:30:42: dot1x-backend(Fa0/3): [3] cont_login returned GETDATA
04:30:42: dot1x-core(Fa0/3): RADIUS reply (2) received
04:30:42: dot1x-authsm(Fa0/3): state AUTHENTICATING, event SERVER_REPLY, arg 0x2
04:30:42: dot1x-besm(Fa0/3): state RESPONSE, event SERVER_REPLY, arg 0x2
04:30:42: dot1x-besm(Fa0/3): state REQUEST, event ENTRY, arg 0x2
04:30:42: dot1x-core(Fa0/3): send EAPOL type=0, EAP code=1, id=3
04:30:42: dot1x-reauthsm(Fa0/3): state INITIALIZE, event SERVER_REPLY, arg 0x2
04:30:42: dot1x-core(Fa0/3): EAPOL pkt in
04:30:42: dot1x-core(Fa0/3): 00:00:39:3F:AA:D1 sent EAPOL type=0, EAP code=2, id=3
04:30:42: dot1x-authsm(Fa0/3): state AUTHENTICATING, event INPUT, arg 0x80B9B7CC
04:30:42: dot1x-besm(Fa0/3): state REQUEST, event INPUT, arg 0x80B9B7CC
04:30:42: dot1x-besm(Fa0/3): state RESPONSE, event ENTRY, arg 0x80B9B7CC
04:30:42: dot1x-reauthsm(Fa0/3): state INITIALIZE, event INPUT, arg 0x80B9B7CC
04:30:42: dot1x-core(Fa0/3): control event
04:30:42: dot1x-authsm(Fa0/3): state AUTHENTICATING, event CONTROL, arg 0x0
04:30:42: dot1x-besm(Fa0/3): state RESPONSE, event CONTROL, arg 0x0
04:30:42: dot1x-reauthsm(Fa0/3): state INITIALIZE, event CONTROL, arg 0x0
04:30:42: dot1x-reauthsm(Fa0/3): reauth timer stopped
04:30:42: dot1x-backend(Fa0/3): [3] relaying EAP data from supplicant
04:30:42: dot1x-core(Fa0/3): send EAPOL type=0, EAP code=1, id=5
04:30:42: dot1x-core(Fa0/3): 00:00:39:3F:AA:D1 sent EAPOL type=0, EAP code=2, id=5
04:30:42: dot1x-authsm(Fa0/3): state AUTHENTICATING, event INPUT, arg 0x80BA0704
04:30:42: dot1x-besm(Fa0/3): state REQUEST, event INPUT, arg 0x80BA0704
04:30:42: dot1x-besm(Fa0/3): state RESPONSE, event ENTRY, arg 0x80BA0704
04:30:42: dot1x-reauthsm(Fa0/3): state INITIALIZE, event INPUT, arg 0x80BA0704
04:30:42: dot1x-core(Fa0/3): send EAPOL type=0, EAP code=1, id=6
04:30:43: dot1x-core(Fa0/3): EAPOL pkt in
04:30:43: dot1x-core(Fa0/3): 00:00:39:3F:AA:D1 sent EAPOL type=0, EAP code=2, id=6
04:30:43: dot1x-authsm(Fa0/3): state AUTHENTICATING, event INPUT, arg 0x80B9B7CC
04:30:43: dot1x-besm(Fa0/3): state REQUEST, event INPUT, arg 0x80B9B7CC
04:30:43: dot1x-besm(Fa0/3): state RESPONSE, event ENTRY, arg 0x80B9B7CC
04:30:43: dot1x-reauthsm(Fa0/3): state INITIALIZE, event INPUT, arg 0x80B9B7CC
04:30:43: dot1x-core(Fa0/3): control event
04:30:43: dot1x-authsm(Fa0/3): state AUTHENTICATING, event CONTROL, arg 0x0
04:30:43: dot1x-besm(Fa0/3): state RESPONSE, event CONTROL, arg 0x0
04:30:43: dot1x-reauthsm(Fa0/3): state INITIALIZE, event CONTROL, arg 0x0
04:30:43: dot1x-reauthsm(Fa0/3): reauth timer stopped
04:30:43: dot1x-backend(Fa0/3): [3] relaying EAP data from supplicant
04:30:43: dot1x-backend(Fa0/3): [3] cont_login returned FAIL
04:30:43: dot1x-backend(Fa0/3): [3] cleaning up AAA context
04:30:43: dot1x-core(Fa0/3): RADIUS reply (1) received
04:30:43: dot1x-authsm(Fa0/3): state AUTHENTICATING, event SERVER_REPLY, arg 0x1
04:30:43: dot1x-besm(Fa0/3): state RESPONSE, event SERVER_REPLY, arg 0x1
04:30:43: dot1x-besm(Fa0/3): state FAIL, event ENTRY, arg 0x1
04:30:43: dot1x-core(Fa0/3): send EAPOL type=0, EAP code=4, id=6
04:30:43: dot1x-besm(Fa0/3): state IDLE, event ENTRY, arg 0x1
04:30:43: dot1x-reauthsm(Fa0/3): state INITIALIZE, event SERVER_REPLY, arg 0x1
04:30:43: dot1x-authsm(Fa0/3): state HELD, event ENTRY, arg 0x0
04:30:43: dot1x-core(Fa0/3): setting default host access to 1
04:30:43: dot1x-core(Fa0/3): deauthorized port
04:30:43: dot1x-besm(Fa0/3): state IDLE, event CONTROL, arg 0x0
Re: 802.1x EAP-TLS Problem
Did you check the IAS logs ? What did they say ?
Also , what IOS version are you running ? What clients are you using ?
Ami
I am using Win2K Pro client with SP4. I am able to set ip up successfully. Even though the port is authorized for the client to access the network, I got the message below when I do the debug dot1x
[3] Unsuccessfully applied per-user acl
[3] Unsuccessfully applied per-user mac acl
Hope you guys can help. Thanks.
355
