802.1x with 2948 GE-TX
Dear all,
I configured 802.1x with an 2950 and IAS ins the LAB, everything is working finde with dynamic VLAN Assignement and Guest VLAN.
I did the same with an 2948, I need to use it (mangement decission they don't want buy new one :-(( )
But I got an error message:
A malformed RADIUS message was received from client 10.1.2.100. The data is the RADIUS message.
Can somebody helps me?
I think it is a setting in the IAS Radius-Client setting, or I'm wrong? I tried Cisco o. Radius Standard.
Thanks, Sebastian
5 Replies 5
Jagdeep Gambhir
Level 10
Level 10
Please make sure shared secret key is same on both ends.
~JG
Hi Jagdeep,
I'm sure!
Attacheed you find my config and IAS eventlog message..
thanks
you might need to install wireshark on the server or somehow otherwise sniff the radius packets. this will give you more information than that event log.
Thanks for the Idea..
Thats the output:
I think the service-types in IAS and the 2948 are not the same..any ideas? I tried with someone but it do not work. But, I get a second erros message in the ias..bevor I type in the password, something tried with another user azbycx, thats strange I think..
No. Time Source Destination Protocol Info
6 30.902648 10.1.2.100 10.1.20.10 RADIUS Access-Request(1) (id=3, l=119)
Frame 6 (161 bytes on wire, 161 bytes captured)
Ethernet II, Src: Cisco_11:b7:42 (00:13:c3:11:b7:42), Dst: Vmware_9c:a8:42 (00:0c:29:9c:a8:42)
Internet Protocol, Src: 10.1.2.100 (10.1.2.100), Dst: 10.1.20.10 (10.1.20.10)
User Datagram Protocol, Src Port: redstorm_join (2346), Dst Port: radius (1812)
Radius Protocol
Code: Access-Request (1)
Packet identifier: 0x3 (3)
Length: 119
Authenticator: 02FA248B0A0C213711B8213325BB1A04
Attribute Value Pairs
AVP: l=13 t=User-Name(1): CISLAB\test
User-Name: CISLAB\test
AVP: l=6 t=NAS-IP-Address(4): 10.1.2.100
NAS-IP-Address: 10.1.2.100 (10.1.2.100)
AVP: l=7 t=NAS-Port(5): [unhandled integer length(5)]
AVP: l=6 t=Framed-MTU(12): 1000
Framed-MTU: 1000
AVP: l=19 t=Calling-Station-Id(31): 00-17-42-21-6e-df
Calling-Station-Id: 00-17-42-21-6e-df
AVP: l=6 t=Service-Type(6): Framed-User(2)
Service-Type: Framed-User (2)
AVP: l=6 t=NAS-Port-Type(61): Ethernet(15)
NAS-Port-Type: Ethernet (15)
AVP: l=18 t=EAP-Message(79) Last Segment[1]
EAP fragment
Extensible Authentication Protocol
Code: Response (2)
Length: 16
Type: Identity [RFC3748] (1)
Identity (11 bytes): CISLAB\test
AVP: l=18 t=Message-Authenticator(80): 35D1789AA9FFED111C540DE63F093A53
Message-Authenticator: 35D1789AA9FFED111C540DE63F093A53
It is working now with Software 8.4. I used 8.3 but this makes trouble in my case.
>Thanks all
