03-05-2014 09:31 PM - edited 03-10-2019 09:29 PM
AAA failed nexus7010
and local username error
# sh run
Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=17(0x11)
03-06-2014 05:31 PM
Can you share the show run?
Is NX 7010 intregrated with TACACS server or its configured for local authentication/authorization?
Did you issue the aaa authorization commands on the switch?
Do you have any local user configured with "network-admin" role?
~BR
Jatin Katyal
**Do rate helpful posts**
03-06-2014 09:35 PM
nexus 7010: AAA failed
but local username
sh run
we configured this at nexus 7010 & failed
tacacs-server key 7 "admin123"
tacacs-server host *.*.*.*
aaa group server tacacs+ tacacs+
server *.*.*.*
server *.*.*.*
deadtime 10
source-interface Vlan**
aaa authentication login default group tacacs+
aaa authentication login console group tacacs+
aaa authorization config-commands default group tacacs+
aaa authorization commands default group tacacs+
aaa authorization config-commands console group tacacs+
aaa authorization commands console group tacacs+
aaa accounting default group tacacs+
03-06-2014 09:37 PM
we are using ACS 5.4
if u have any idea pls guide
thanks in adv
03-06-2014 10:07 PM
Are you able to access the switch using local credetials? If yes can you provide the "debug tacacs", "debug aaa authen" and "debug aaa author" and show version from the switch.
Also, what all configuration do you have on the ACS side for the NX7K?
~BR
Jatin Katyal
03-06-2014 10:26 PM
local login
# sh run
ACS
03-06-2014 10:31 PM
ACS key mismatch
03-07-2014 07:41 PM
so there was an issue with key mis-match? Did you figure out the same in the debug outputs?
~BR
Jatin Katyal
03-08-2014 08:36 AM
Was that an issue with shared secret mis-match? were you able to find that in the tacacs debugs?
