11-17-2010 06:13 AM - edited 03-10-2019 05:35 PM
Hi all,
I have some problems with the VRF that I made and the radius verification.
The problem is that it's imposlible to make authentication through the radius server.
The debug output is :
000103: Nov 17 14:26:02: RADIUS/ENCODE(00000004):Orig. component type = EXEC
000104: Nov 17 14:26:02: RADIUS: AAA Unsupported Attr: interface [171] 4
000105: Nov 17 14:26:02: RADIUS: 74 74 [ tt]
000107: Nov 17 14:26:02: RADIUS(00000004): Config NAS IP: 0.0.0.0
000108: Nov 17 14:26:02: RADIUS/ENCODE(00000004): acct_session_id: 4
000109: Nov 17 14:26:02: RADIUS(00000004): sending
000110: Nov 17 14:26:02: RADIUS/ENCODE: Best Local IP-Address 192.168.1.50 for Radius-Server 192.168.1.10
000111: Nov 17 14:26:02: RADIUS: No secret to encode request (rctx:0x5935DF4)
000112: Nov 17 14:26:02: RADIUS: Unable to encrypt (rctx:0x5935DF4)
000113: Nov 17 14:26:02: RADIUS(00000004): Send Access-Request to 192.168.1.10:1645 id 1645/4, len 84
000114: Nov 17 14:26:02: RADIUS: authenticator 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
000115: Nov 17 14:26:02: RADIUS: User-Name [1] 8 "****"
000116: Nov 17 14:26:02: RADIUS: User-Password [2] 18 *
000117: Nov 17 14:26:02: RADIUS: NAS-Port [5] 6 2
000118: Nov 17 14:26:02: RADIUS: NAS-Port-Id [87] 6 "tty2"
vpn003151ro110#
000119: Nov 17 14:26:02: RADIUS: NAS-Port-Type [61] 6 Virtual [5]
000120: Nov 17 14:26:02: RADIUS: Calling-Station-Id [31] 14 "192.168.1.20"
000121: Nov 17 14:26:02: RADIUS: NAS-IP-Address [4] 6 192.168.1.50
000122: Nov 17 14:26:02: RADIUS(00000004): Started 5 sec timeout
000257: Nov 17 14:26:02: RADIUS: Retransmit to (192.168.1.10:1645,1646) for id 1645/8
000258: Nov 17 14:26:02: RADIUS(00000004): Started 5 sec timeout
000268: Nov 17 14:27:05: RADIUS: No response from (192.168.1.10:1645,1646) for id 1645/8
000269: Nov 17 14:27:05: RADIUS/DECODE: parse response no app start; FAIL
000270: Nov 17 14:27:05: RADIUS/DECODE: parse response; FAIL
From witin the vrf I can ping the radius server. From the radius server I can ping the router
So I don't understand where it's gonig wrong
The little config is :
aaa group server radius radius_1
server 192.168.1.10 auth-port 1645 acct-port 1646
ip vrf forwarding vpn01
ip radius source-interface Vlan200
vlan 200
name vpn01
interface Vlan200
ip address 192.168.1.50 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf authentication-key 7 ********
In global
radius-server host 192.168.1.10 auth-port 1645 acct-port 1646
ip route vrf vpn01 0.0.0.0 0.0.0.0 192.168.1.254
11-17-2010 09:27 AM
can you check to see if the radius server is receiving the packets or not ?
Nicolas
09-08-2011 03:35 PM
Hello Radek, Nicolas, community,
I am currently experiencing the same exact issue...Trying to perform authentication on a 6500 12.2(33)SXH6 where multiple vrf are configured (vrf A can communicate with the radius)
My configuration is almost the same as yours with following difference :
In global
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key string
(+ global ‘radius-server key string’)
ip radius source-interface vlan 10 vrf A
The debug is similar as yours (file in attachments), the Radius does receives something but the authentication is denied and nothing is returned to the switch exaplaining the retransmission/timeout messages at the end (same secret and key double checked and validated) .
FYI it is working well for other 6500 without VRF in 12.2(33)SXI)….
Did your authentication issue solved, and if yes how ? Or any idea explaining this authentication problem ?
Any suggestion will be appreciated !
Thank you very much.
Regards.
Karim
09-08-2011 10:22 PM
Troubleshooting path would be the same :
You say that the radius server receives the request. It then sends back an access-reject ? If yes, what is the failure reason marked on the radius server ?
09-09-2011 01:44 AM
Hello Nicolas,
Many thanks for your reply.
As stated the server receives the request, rejects it but the server does not send back an access-reject to the 6500...
================Server log===================================
[unix] invalid password "my_username"
++[unix] returns reject
Failed to authenticate the user.
WARNING: Unprintable characters in the password - Double-check the shared secret on the server and the NAS!
What is stucking me is the warning message in the server logs => We DO use the same secret.
And the same user authenticates without any problem in other 6500 not using VRFs...
Thanks anyway.
Regards.
Karim
09-09-2011 06:21 AM
Ok problem solved.
I don't know why but my Sup720-10G 12.2(33)SXH5 was sending the request throug Radius extended source-port.
1097078: Sep 8 12:47:22: RADIUS(00000C82): Send Access-Request to X.X.X.X:1812 id 21645/118, len 81
And the server did not like it, thus rejecting the Authentication.
Adding the hidden command in global config =>
"radius-server source-ports 1645-1646" resolved the situation.
The authentificaiton is now OK;
Thanks anyway.
Kind regards.
Karim
