05-02-2006 11:18 PM - edited 03-10-2019 02:33 PM
I am running CiscoSecure ACS v3.0 for Windows 2000/NT Release 3.0(1) Build 40 in my environment. I have a problem when adding AAA clients in a network Device Group as it gives an error saying the device already exist.
I have done a manual search of the device and it cannot be found. Is there any other way of removing that device by ip address which the system already think exist.
Obine
Solved! Go to Solution.
05-03-2006 12:54 AM
Hmm, do you enter device IP addresses, ranges or DNS names?
Could it be there is an accidental overlap somewhere?
You can use regedit to inspect the network config db. It lives under HKLM/SOFTWARE/Cisco/CiscoAAAv3.3/Hosts
If you spot the duplicate you can simply delete its sub-key then re-start all the CS**** services (including CSAdmin) from the control panel.
Darran
05-03-2006 12:54 AM
Darran
05-03-2006 02:44 AM
Thanks Darran,
you were spot on with your solution. I have been able to sort this out now.
Obine
