AAA policy help
Bharat Negi
Hi All
user1 >>>GroupA & user2 >>>GroupB
Router1 >>>NDG-A & Router2 >>>NDG-B
Now,
GroupA user must have "sh run" permission on NDG-A but not on NDG-B.
GroupB user must have "sh run" permission on NDG-B but not on NDG-A.
I created two shell command authorisation set and mapped it to GroupA & GroupB. Then inside the Group, I mapped the Shell command set to NDG. Here I have two associations.
(**I have tested with single association and its working. But not not with two)
But somehow its not working.
Please help.
Bharat
Jagdeep Gambhir
Level 10
Level 10
Bharat,
You need to set up Assign a Shell Command Authorization Set on a per Network Device Group Basis
In GroupA---> Assign a Shell Command Authorization Set on a per Network Device Group Basis---->
Add NDG A<====> Allow show run set**
Add NDG B<====> Deny all***
In Group B----->Assign a Shell Command Authorization Set on a per Network Device Group Basis---->
Add NDG B<====> Allow show run **
ADD NDG A<====> Deny all***
** Command autho set allowing Only show run
*** Command author set that deny's every thing.
Please check this link,
http://cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
Hope that helps !
~JG
Do rate helpful posts
Hi Thanks for your reply. But this thing I have already done on ACS.
After intorducing following commands on Router, it worked.
aaa authorization commands 1 default tacacs+ local
aaa authorization commands 2 default tacacs+ local
aaa authorization commands 3 default tacacs+ local
aaa authorization commands 4 default tacacs+ local
aaa authorization commands 5 default tacacs+ local
aaa authorization commands 6 default tacacs+ local
aaa authorization commands 7 default tacacs+ local
aaa authorization commands 8 default tacacs+ local
aaa authorization commands 9 default tacacs+ local
aaa authorization commands 10 default tacacs+ local
aaa authorization commands 11 default tacacs+ local
aaa authorization commands 12 default tacacs+ local
aaa authorization commands 13 default tacacs+ local
aaa authorization commands 14 default tacacs+ local
aaa authorization commands 15 default tacacs+ local
Thanks for your help
Bharat
We need to have these commands on the router. You never mentioned it in your orignal post.
Anyways , there is no need to put 15 line on the router. Just three will take care
i.e.
aaa authorization commands 0 default tacacs+ local
No need to count from 1 to 15.
~JG
